04-13-2013, 10:52 PM | #1 |
Changing TH350 Dipstick.
This is probably a really stupid question but how hard is it to change a dipstick on a th350? I've opened the hood 6 times or so since I started driving my truck again and everytime the dipstick has been sticking out of the tube. I want to get a locking dipstick so that doesn't keep happening. Do the dipsticks simply "pop out" of the trans or will I need to drop the pan or something?
Thanks, Michael.
Michael Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9 |
04-14-2013, 12:03 AM | #2 |
Re: Changing TH350 Dipstick.
uuum your case vent is clogged most likley, and pressure is making it come out......
04-14-2013, 01:13 AM | #3 |
If your vent is blocked, a locking dipstick will make it leak somewhere else.
However, to answer your original question, it's really simple. It's held in by a bracket under one of the bellhousing bolts on the passenger side. The only connection to the transmission is an o-ring about an inch from the end of the tube. Make sure you put a little transmission fluid on the o-ring before you install the tube so it doesn't bind. |
04-14-2013, 11:27 AM | #4 | |||
"I ain't nobody, dork."
Gary
04-14-2013, 11:35 AM | #5 |
Get up under the truck and near the top of the case on the driver side you will find a tube (hopefully) if not there will be a hole with some kind of crud in it. You need to get the vent open first and foremost. The dipstick isnt your issue. Heres a picture of where the vent is. http://www.google.com/search?q=th350...31%3B600%3B450
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
04-14-2013, 04:03 PM | #6 |
Hmm, this isn't good news to me. Transmission is brand new for the new engine. Is it common for new vent tubes to be installed wrong on new transmissions or something? I might just drive it down to the tranny shop and see what they can do.
04-14-2013, 05:57 PM | #7 |
Bugs like to make homes in funny places.......
but if you can get them to do it free, id let em crawl under it. maybe it was over looked |
04-14-2013, 06:29 PM | #8 |
A lot of TH350's don't use an actual tube, They use a "push-in" breather, Still available from the dealer/ACdelco
04-14-2013, 09:43 PM | #9 |
I looked back over some pictures I had of the install and that's what mine has....maybe the cap got stuck closed or something? I'll have to check it out and if I can't figure it out I'll just take it down to the shop.
04-15-2013, 11:44 AM | #10 | ||
If the shop removed it and plugged the hole... find a different shop.
Gary
