Old 02-04-2004, 08:11 PM   #1
TIMSPEED
TIMSPEED's Avatar
Difference in compression ratio going from 76cc to 64cc??
If I'm running 8.5:1 Compression right now, with a 76cc Head, and I swapped to a 64cc Head, would that bump my compression ratio up to 9.5:1 or 9:1?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-04-2004, 09:55 PM   #2
smitty62
smitty62's Avatar
With flat heads, more like 9.8 maybe 10 : 1
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-04-2004, 10:20 PM   #3
bigjimzlll
bigjimzlll's Avatar
with a .040 quench..figuring 11cc piston dish..with 64cc heads..the cr is 9.54-1 If you have flat tops with a .065 quench(.039 gasket+.025 piston down) and add 64cc heads the CR will be 9.66-1 if you add a shim gasket(.015) The cr will be 10.2-1
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 02-05-2004, 03:50 AM   #4
TIMSPEED
TIMSPEED's Avatar
I don't know what kinda pistons I have...just stock I guess??? I think they're like flattops..but like, they have a lip around the edge. Like, the center is taken down lower than the outer edge.
9.6:1 would be perfect...
See Them Here
Old 02-05-2004, 10:14 AM   #5
Bowtie67
Bowtie67's Avatar
Post
JMO, General rule of thumb is 8.5cr @ 76cc - 64CC =12CC + 8.5 should get you pretty close to 9.7CR, without getting real technical with head gaskets, quench, etc. This should be fine with cast iron heads depending on Cam with out having to worry about pinging, with Aluminum, you can usually get away with 10.2cr Cam Pending. Too short of a cam duration bumps running CR up, long duration lowers running CR, too long a Duration cam with out other mods results in low performance.
Bowtie67 is offline   Reply With Quote
Old 02-06-2004, 05:35 PM   #6
GSXMEN
I'd say Jim's #'s look spot on!! The 'rule of thumb' I've heard for SBC's is 1.1 pts. difference when going either to or from 64cc - 76cc.
Scott
GSXMEN is offline   Reply With Quote
Old 02-06-2004, 05:40 PM   #7
cableguy0
timspeed those arent flat tops they are dished pistons
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 02-06-2004, 11:45 PM   #8
jbw0127
Try this!
If you know all the numbers, this works great!
http://www.classictruckshop.com/garage/shopmathcr1.asp
72 swb Cheyenne
"nut & bolt" frame off (in process)
Blown 383
jbw0127 is offline   Reply With Quote
Old 02-07-2004, 01:21 AM   #9
lukecp
Formerly yellow72custom
lukecp's Avatar
What Cabelguy said. Flattops are completely flat, except most have small valve reliefs in the middle. You proably have like 8.0:1 compression right now.....64cc heads would put you into the 89 octane gas range. I run 89 octane in my flattop-pistoned 64cc chamber 350 and it works pretty good.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
