Old 11-19-2017, 09:29 AM   #1
1jfhj2
Reservoir beside brake booster
Good morning. I ordered my new brake booster and master cylinder for my 69 C20 dually and while waiting I decided to spray everything I need to remove so it will come apart easier. Can anyone tell me what the extra reservoir is to the right of my brake booster. Unable to find any pics of other trucks with that in it. Thanks
1969 GMC C20
2001 Chevy Silverado 1500HD Crew Cab
2005 Chevy Silverado 3500 Crew Cab Duramax
1jfhj2 is offline   Reply With Quote
Old 11-19-2017, 10:04 AM   #2
Jcfcamaro
Jcfcamaro's Avatar
Re: Reservoir beside brake booster
Hydraulic clutch?
Jcfcamaro is offline   Reply With Quote
Old 11-19-2017, 10:09 AM   #3
1jfhj2
It is a 4 speed but I didn't think they had hydraulic clutch that early.
1969 GMC C20
Old 11-19-2017, 10:41 AM   #4
jocko
jocko's Avatar
It's likely a slave cylinder for the clutch - not a hydraulic release bearing like they have today. Look where your clutch actuating lever connects to the bell housing and see if you have a push cylinder rather than mech linkage. They had this setup as early as 1960, it used to be part of the main master cylinder. But, this setup looks like an old single pot brake mc (which would work for the clutch) from 63-66 trucks (and cars) - have not seen one on a 69.
Old 11-19-2017, 12:09 PM   #5
RodnRudy
RodnRudy's Avatar
Since there's no line coming out of the old single port MC the clutch linkage has probably been changed to mechanical?
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 11-19-2017, 01:09 PM   #6
geezer#99
geezer#99's Avatar
It could be the master needed for a hydraulic trailer brake set up.
Old 11-19-2017, 01:38 PM   #7
truckster
truckster's Avatar
Most likely answer. Look under the dash to see if there's a rod connecting this MC to the brake pedal.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 11-19-2017, 09:44 PM   #8
mike16
might also be part of a big truck set up
mike16 is offline   Reply With Quote
