04-20-2014, 09:23 AM | #1376 |
Re: 68 S/C update.....
New tank is installed!! Very high quality piece from Boyd's tanks. Craftsmanship is top notch. My only quibble was with the placement of the vent/rollover valve - it's right under one of the bed braces making it very difficult to get to. 3" more to the front and it would have been perfect. Oh well, I just put the hose on before I put the tank up in the hole. Other than than that, I would highly recommend it.
While I had the tank out I also redid my fuel filler neck with a bigger pipe (2"). When I had originally put the filler neck together, I used an 1.75" pipe and then flared the end that connects to the tank which was a 2". It worked most of the time, but if I got a gas pump the flowed really fast, it would burp fuel. So this time, I used 2" pipe for the entire piece. I know that's not a lot bigger, but that's all the room I have up in the bedside. Hopefully it let everything flow a little better than the other one. I also welded a bracket to the pipe to mount it to the bed floor. The tie wrap I've had on there for the last 4 years needed to go
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-20-2014, 10:46 AM | #1377 |
More pics
04-20-2014, 11:02 AM | #1378 |
That looks real good Rob!
-Rus |
04-20-2014, 11:04 AM | #1379 |
Rollin' Old Skool
That looks nice Rob! Dig the slight stance alteration as well.
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
04-22-2014, 01:17 PM | #1380 |
Still Learning
Rob, Do you have any more info about the fuel door/lamp housing install? Do you know what donor vehicle the hinge came from? How is it fastened? I am planning to do the same install for my filler. One more question, how did it fill at the station? plenty of flow? thanks |
04-22-2014, 01:41 PM | #1381 |
It's just for show. This truck does not run on gas... It runs on plutonium. He has one of these in the buddy console
68 BB burb build thread Scott's super slam front/rear http://67-72chevytrucks.com/vboard/s...d.php?t=378084 |
04-22-2014, 03:26 PM | #1382 | |||
Thanks Rus!
http://67-72chevytrucks.com/vboard/s...d.php?t=380571 If you have any other questions. Let me know.
04-22-2014, 04:09 PM | #1383 |
Knuckle head
This thing is looking amazing. Are you still working on the tranny program? I got my '09 dialed in pretty good but I am still not happy with my power downshift.
This truck has a lot of parts that I am interested in. The Dakota Digital gauges you have how did you work the OBDII interface? Also, did you get the boost referance gauge from DD? I may have missed it, but how did you hook the paddle shifter up to the trans and is it the only thing used to shift the trans?
Adam '71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. |
04-22-2014, 08:30 PM | #1384 | ||
http://www.hptuners.com/forum/showth...Table-Software I used the Dakota digital BIM -01-1 OBDII interface. I have a NGK wideband that has a display and plugs into my HPTuners interface so I can also datalog it. The paddle shifters have a wireless interface that connects to the Tap up Tap down (TUTD)wire the Speartech pulled when he build my harness. The only way an A6 can be shifted "manually" is with a TUTD switch.
05-13-2014, 11:41 AM | #1385 |
No big updates. Just fine tuning a few things. The new tank and filler tube are working great. I have filled it several times and other than having to be careful when it's almost full, I have had zero problems.
05-13-2014, 05:38 PM | #1386 |
Those gauges would look good in my truck lol.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
05-18-2014, 10:52 AM | #1387 |
, yes they would, .
Picked up some bling bling for the truck yesterday. Do you guys think it will look out of place?
05-18-2014, 02:10 PM | #1388 |
I wouldn't do it Rob, looks too... Country? Even for the "farm" truck.
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
05-18-2014, 02:23 PM | #1389 |
Rollin' Old Skool
That'd be great for the sleeper look, but you gotta think they'd know something is up when they see those huge meats you're rolling in the rear. Oh, & I'm sure it doesn't sound too sleeper-ish either?
05-18-2014, 02:59 PM | #1390 |
A day late and $1 short...
I'm waiting for pics with the topper on the truck!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
05-18-2014, 03:39 PM | #1391 |
^^^^me too!!
-Rus |
05-18-2014, 05:16 PM | #1392 | ||
05-18-2014, 06:09 PM | #1393 |
I say roll with it. It looks old school country cool.
Can you give us a full side shot of the whole truck with the topper? Mike |
05-18-2014, 11:16 PM | #1394 |
X2... but so far I think it looks cool. Some big (20") truck ralleys would look cool with the topper.
05-18-2014, 11:56 PM | #1395 |
Still Learning
Heck yeah Rob! you're ready to go camping at the lake now
05-19-2014, 12:53 AM | #1396 |
Guess I'm the odd ball here! Heck no! Pull that thing off.
05-19-2014, 07:17 AM | #1397 |
Vintage Evil
05-19-2014, 07:58 AM | #1398 | ||
Thanks! Different strokes I guess. Cool thing is, I can pull it off in 5 minutes, Here are some better pictures.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-19-2014 at 09:57 AM. |
05-19-2014, 09:51 AM | #1399 |
Lose the camper IMO
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435 |
05-19-2014, 09:53 AM | #1400 |
I LOVE it!
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
