Old 02-19-2016, 10:06 AM   #26
Lattimer
Lattimer's Avatar
Re: FITech Installation - Vent Line
Originally Posted by NC_John View Post
Well, hopefully I won't need to deal with them directly on anything and the juice is worth the squeeze for all the time, money and effort to do this.
If all goes well and I don't hit any more bumps, I hope to have it running this weekend. The truck is laid up in the "premium (easy access)" bay in my garage, just stuck there, in the way right now. It needs to move!
Let us know how you make out with the vent. If you can make it work, it would probably lead me to buy this setup.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 02-19-2016, 10:09 AM   #27
NC_John
NC_John's Avatar
I'll do it!
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 02-19-2016, 11:00 AM   #28
rcazwillis
Technically, a vent and a return line are different items. Could you vent to a charcoal canister? Not sure if that works, but just a thought.
I helped an uncle finish the install of a FITech unit on a '32 coupe last weekend. I was impressed with the product. 4 wires, high pressure line from tank, return line to tank, sensor bung in exhaust. Turned the key and it fired right up. Had a holley carb on it prior, the FITech was noticeable better immediately. It could not have been simpler. My uncle spoke to their customer service on the phone four times last week and had nothing but positive things to say about his experience. Hopefully, your email interaction is an exception. I will be using one down the road.
rcazwillis is offline   Reply With Quote
Old 02-19-2016, 11:08 AM   #29
Lattimer
Lattimer's Avatar
I thought about that, and I actually have a canister laying on a shelf that I could use. FITech said no way.
Its hard to judge what is them covering their asses for liability and what is an actual requirement.
The guy I was emailing with (never gave his name, it was a generic FiTech email) pissed me off when he said "you need to just suck it up and move the bomb out of the cab."
Shawn
Old 02-19-2016, 11:24 AM   #30
rcazwillis
I would not have had anything positive to say about that comment either. My uncle was not confident in his ability to do the install and was "bugging" them with questions about how to install. Things like fan relay control, timing control etc. They were fairly clear in the instructions, but the tech guy was very patient with him. He can be critical at times, but was very upbeat. Maybe you should give them a call vs email.
Old 02-19-2016, 11:27 AM   #31
Lattimer
Lattimer's Avatar
Maybe.
At the moment I'm waiting and hoping to see someone successfully install the FCC with a stock non-EEC tank so I can copy whatever they do on the vent....
I have a perfectly good running carb right now, but I really want some of the things fuel injection offers, like managing idle speed when the AC compressor cycles. But I'm not willing to make a $1300 mistake just because of that little vent line.
Shawn
Old 02-19-2016, 11:43 AM   #32
NC_John
NC_John's Avatar
But the mechanics of installing one are not which is the point.
I considered using a charcoal canister but another member pointed out they want it back to the tank in case the float valve in the command center sticks. If it does, you are returning straight fuel to the tank.
1970 C-10 LWB "Blu"
Old 02-19-2016, 11:49 AM   #33
jr54international
jr54international's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=696396
..........................____
...............______//__{\___
............./__(0)_//__/_(0)_/
LS powered 54international build
http://67-72chevytrucks.com/vboard/s...d.php?t=657553
jr54international is offline   Reply With Quote
Old 02-19-2016, 03:56 PM   #34
NC_John
NC_John's Avatar
Originally Posted by jr54international View Post
What he did is all fine, again, until the float sticks in the command center and he is pouring gasoline out onto the street. And who knows how long it could do that going unnoticed.
1970 C-10 LWB "Blu"
Old 02-19-2016, 04:24 PM   #35
TA1968
TA1968's Avatar
Originally Posted by Katrina/10 View Post
I tried using that extra port on the later model sending unit as a vent, and it didn't work. It is most definitely submerged when you have a full tank, and will push lots of fuel out that line with a non-vented cap. Those are supposed to be hose clamp fittings.
Did you try a vented cap?
Or can't you buy one for your year truck.
TA1968 is offline   Reply With Quote
Old 02-19-2016, 05:09 PM   #36
Lattimer
Lattimer's Avatar
That is exactly my concern.
Shawn
Old 02-19-2016, 08:56 PM   #37
KyFarm
KyFarm's Avatar
my feelings as well
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 02-19-2016, 11:41 PM   #38
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I don't like the tank in the cab, and I don't want to vent the FCC into my cab tank.
I'll be installing a tank under the bed.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 02-19-2016, 11:52 PM   #39
Nitis
Nitis's Avatar
Can someone who is smarter than me explain why it matters if the vent line is submerged? If you have a vented cap what difference does it make the pump isn't going to run backwards? I cant foresee fuel going backwards through the vent line and if that was a concern I am sure there is some sort of check valve system available.
At this point Its probably no more labor intensive and probably more cost effective to just install an inline if one needs to use the in cab tank.
Nitis is offline   Reply With Quote
Old 04-13-2018, 09:28 PM   #40
LostMy65
LostMy65's Avatar
Did you ever get an answer to your question?
