Old 07-18-2018, 07:03 PM   #26
Sawlog
Re: Getting my speedo to be more accurate
Originally Posted by Rich69shortfleet View Post
When I changed the truck to 3.73 gears (from 3.07 gears) I did the calculations and changed the speedo driven gear to get the speedo back into calibration. However, a few weeks ago I was traveling with a friend. Our speedometer readings didn't match. I told him I was going to drive 65 and so he did too and he pulled away. So, apparently my speedometer is reading fast, or his is off too!
Anyway, on the way home at 100 miles from home I noted the odometer reading. This 100 miles was covered on the Interstate with never leaving the Interstate. When I reached home, the odometer was reading 7 more miles than it should have given the 100 miles covered. So, my speedometer and odometer are reading 7% fast.
If I recall correctly, on the driven gears one tooth is worth about 5% increase or decrease, depending on which direction you go. So, to slow down my speedometer to more closely match the speed I'm going, I'd want to find a driven gear one tooth larger than what I have now. I still need to pull the bullet and see which gear I have since I honestly don't remember, but I was hoping others here can help check my logic on what I need to do, ie: get a driven gear one tooth larger.
TIA
I don't know what tranny you have... But how do you like the gear change?
Sawlog is offline   Reply With Quote
Old 07-18-2018, 07:34 PM   #27
Rich69shortfleet
The transmission is a TH350. I like the gear change a lot. It was hell towing a 6000 lb car/trailer combination with 3.07 gears. It is a lot peppier too. If I didn't want to haul heavy loads or pull heavy things the 3.07s would have been fine, but they absolutely sucked when trying to work the truck hard.
Rich69shortfleet is offline   Reply With Quote
Old 07-18-2018, 09:45 PM   #28
Sawlog
The transmission is a TH350. I like the gear change a lot. It was hell towing a 6000 lb car/trailer combination with 3.07 gears. It is a lot peppier too. If I didn't want to haul heavy loads or pull heavy things the 3.07s would have been fine, but the absolutely sucked when trying to work the truck hard.
Can you still cruise at 65-70 mph ok? I have 3.07s in my c10 now and am wanting some more get up. Thinking 3.42 or 3.73.
Old 07-19-2018, 08:44 AM   #29
Rich69shortfleet
Well, I can, but the engine is at about 3400 at 70 MPH so I typically keep it to 65 MPH when travelling at highway speeds. I would really like to eventually install a more modern transmission with an overdrive.
