Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 04-07-2020, 09:24 AM   #1
Dodge68charger
Radio In Glove Box
Anyone Done This and Have Pics of How They Mounted It. Thank You
Dodge68charger is offline   Reply With Quote
Old 04-07-2020, 04:27 PM   #2
rockyrivermark
Re: Radio In Glove Box
Not in glove box but did install a hidden Bluetooth.
I removed my behind the seat gas tank and made a speaker box in its place.
On the one end of the speaker box I installed a round flush mount marine Bluetooth stereo so with door open I can still adjust settings if needed but most everything is controlled from smart phone.
Then install a toggle under dash to turn it on or off
I kept my working am radio in place.
I installed
metal on the back of the seat. Otherwise the foam deadened the sound.
You can’t tell where the sound is coming from. Sound quality is really good.
Hidden Bluetooth and working original am radio.
Just a thought.
Of course it only works if you have rear gas tank.
My build page
http://67-72chevytrucks.com/vboard/s...d.php?t=764662
My cabinet building site
http://www.cbcabinets.com
rockyrivermark is offline   Reply With Quote
Old 04-07-2020, 04:47 PM   #3
67swb72klb
67swb72klb's Avatar
I just said screw it and cut the dash for the new radios..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 04-07-2020, 04:59 PM   #4
blue betty
I did this quite a few years ago. I ended up making a box out of MDF board glued and nailed together. Then I covered the box and the inside of the glove box with speaker carpet as well as the door and made the cupholder. I made a template out of cardboard so all the angles and contours were perfect then traced it onto the wood and it holds the stereo no problem it’s actually only three sides. Very solid as the stereo doesn’t weigh much. It’s all on the right side of the glove box I still have room for owners manual spare fuses duct tape. LOL my stereo had a remote which was very helpful because of its location.Easy to pull out and get access to if you need as well. Cheers
1967 GMC Fleetside. (Betty)
1985 Chevy Shortbox 4X4.(Freddy)
blue betty is offline   Reply With Quote
Old 04-07-2020, 05:12 PM   #5
blue betty
Here’s a picture of my glove box. Pretty simple design nice and tucked into that corner. Same stereo I installed 15 years ago. If I recall I put an extra support on the front face of the wood to help hold the stereo in place. Cheers
Old 04-07-2020, 07:20 PM   #6
KY_GMC
KY_GMC's Avatar
Here is my install. The newer radios are not as deep as they used to be. No need to cut the glove box.
http://67-72chevytrucks.com/vboard/s...d.php?t=768090
1972 GMC 1500 Super Custom, 383 Stoker, TH350
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592157
Engine Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=592233
KY_GMC is offline   Reply With Quote
Old 04-07-2020, 10:30 PM   #7
jocko
jocko's Avatar
Old 04-07-2020, 11:00 PM   #8
Killer Bee
Killer Bee's Avatar
my 71 K20 burb came with this in the glovebox and kick panel speaker covers..
not my style and probably remove eventually, but very thankful he spared the dash and doors from the sawzall
friends don't let friends hack!
my poor old K1500 burb dash was butchered with a dull knife and a block of wood..
thankfully brothers had this on sale a while back and cleaned it up a bit..
if I was a digital kind of guy, this would be my first choice, does everything but play cds..
https://www.radiosforoldcars.com/new...hevtruck70.htm
Old 04-08-2020, 03:38 PM   #9
67swb72klb
67swb72klb's Avatar
I know lol I also took all the air condition stuff out and used the outside vents for tweeters (most of it was missing anyway)
Old 04-08-2020, 04:55 PM   #10
LuckyScott
LuckyScott's Avatar
I use Custom auto sounds. They make great stuff that fits the stock opening. You can go conservative or wild. In my 70 truck I went with just the radio and a dual speaker that fits in the stock speaker location under the dash.
In my 72 suburban I did the kick panel speakers and door speakers. (Previous owner had already cut the holes in the doors so might as well fill them up with speakers)
and then I installed a subwoofer under the back seat. Sounds awesome.
LuckyScott is offline   Reply With Quote
Old 04-08-2020, 07:56 PM   #11
kaycee
kaycee's Avatar
You guys with glove box stereo ,dont you have to have the door open to adjust volume,channel etc. ?
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-08-2020, 09:05 PM   #12
Killer Bee
Killer Bee's Avatar
^ yes unless it has an rf remote..
ironically my hacked dash sub radio has a remote but the glovebox radio doesn't
Old 04-09-2020, 11:04 AM   #13
kaycee
kaycee's Avatar
OK stereo's are not my strong point, I am looking for a set up for my 63 Impala without cutting dash. I now have a single din mounted under dash in a custom box
2005 FXDWG stage3
63 IMPALA 327
Old 04-09-2020, 01:04 PM   #14
Killer Bee
Killer Bee's Avatar
if your looking for digital functions in original appearence,
scroll down to chevrolet and 1963, menu of 8 radios opens..
click on the '63 impala option.. or write in 'impala' in step above..
https://www.radiosforoldcars.com/newradiochev63.htm
Old 04-09-2020, 09:17 PM   #15
kaycee
kaycee's Avatar
Holy Batcrap Batman they proud of them stereos ,can't do that but thanks anyways
2005 FXDWG stage3
63 IMPALA 327
Old 08-12-2020, 02:21 PM   #16
Dukk
Lightbulb Re: Radio In Glove Box
Yes this is an old thread but continuously relevant..
IF you can live without AM/FM, there are a number of really clever Bluetooth options these days.
This one from MTX fits into a standard square switch hole: https://www.mtx.com/awbtsw-rocker-sw...er-and-control
Wetsounds sells a very similar one to the MTX and also has one that will fit into a round hole. Lighter replacement anyone? https://www.wetsounds.com/product/WW-BT-VC-V2
Dukk is offline   Reply With Quote
