04-06-2020, 08:36 PM | #1 |
4 inch lift install question
I just received my 4 inch lift. Springs all the way around and dual steering stabilizer and extended brake lines. Do I need the drop pitman arm for the install or will the stock arm work. Everything I have read some say yes, most say no. The kit didn't come with one. But other of the same kits for different year trucks do come with one. I guess I could fit it together and find out. I just don't want to have to wait a week to get the part if I need it. Any one have a 4 inch lift with the stock arm? Thank you.
Its for a 1972 GMC K2500 |
04-06-2020, 09:18 PM | #2 |
Re: 4 inch lift install question
4” is right on the edge. 6" lift definitely needs a dropped Pittman. with a 4 inch lift, personally, I would recommend the dropped Pittman arm or offset draglink, otherwise you will likely notice reduced steering radius ( to the left of I remember correctly)
04-06-2020, 09:30 PM | #3 | |
I am going to replace the body mounts why I'm under there. Thanks for your suggestions. |
04-06-2020, 09:39 PM | #4 |
I bought a raised pitman arm on my 4in lift. It sure helped out on the angle of the tie rod ends.
04-06-2020, 09:44 PM | #5 |
Hey Conoco, what kit did you go with? Just curious cuz shipping suspension parts to AK is expensive! I went with BDS for my FJ40 because I could buy it locally and hated it.
Are you at home or stuck on the slope?
1972 GMC K2500 Super Custom Matt |
04-06-2020, 09:45 PM | #6 |
Definitely run the Dropped Pitman arm at a minimum, but if you can consider going to Crossover steering. It is a much better system. Super solid, stable, and fixes all the angle issues in the entire steering system.
04-06-2020, 09:58 PM | #7 | |
I went with the roughcountry. I was looking at all of them and read the reviews for them, tuff country and skyjacker. Price wasn't the issue but I refused to pay tuff country and skyacker 500 dollars in shipping. Rough country not only dropped there price by $130 yesterday but then there shipping was only $180. I understand shipping is always a pain to come to aAaska, but when the other lift kits wanted more that half of what the lift kit cost in the first place for shipping, I gotta draw the line somewhere. I saw enough rough country reviews and videos to make my decision. I am not picky on the ride stiffness. Its an old truck, not a new tahoe. I think because all the businesses are hurting pretty bad right now that they are practically giving stuff away. I was going to order this kit last week. I am glad I waited. I saved almost 400 bucks and went ahead and ordered the dual steering stabilizer and stainless steel brake lines for the front and rear. I'm sure I will be pleased. If i'm not I will still drive it with a smile You in fairbanks? You guys getting hit pretty hard from what I have been reading. I will install the kit and everything else starting on the 25th. I will shoot you some pics and let you know how it drives. Stay safe brother. |
04-06-2020, 10:00 PM | #8 |
I will look into this. I briefly started reading stuff on it and it looks like alot of stuff has to be changed and upgraded. I will do some more research. Your right though, everything I have seen so far tells me that cross over is the way to go!! if you have any input on the parts involved that would be awesome. Stay Safe
04-07-2020, 12:10 AM | #9 | |
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-07-2020, 12:48 PM | #10 |
Currently Blazerless
Your much better off going with a 4" raised steering arm. It will get your drag link level and will steer much better than the drop pitman arm.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
04-07-2020, 01:37 PM | #11 | |
Probably don’t have a 4 wheel parts in your town but they ordered me a skyjacker 2.5 softride with free shipping. It was like $600 and less than &1000 total installed
04-07-2020, 05:44 PM | #12 |
So I bought the 4 inch raised steering arm. The only one I could find was for a 1973 and up. I was confused at first. I checked LMC and looks like the steering arms are identical for the 72 and 73 and up. The one I purchased is the SuperLift 3000 4 inch raised steering arm. On 2 websites it shows it fits for a 67-72 gmc, but on the other two websites it says it doesn't fit. Hopefully it does. I will post a picture of the before and after for all you guys. Thanks for the help.
04-07-2020, 09:21 PM | #13 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-07-2020, 09:54 PM | #14 |
Have fun getting the original steering arm off, took me 3 days. Would have been a much easier job if axle wasn't still under the truck.
1972 Blazer Highlander 1971 GMC K1500 SWB (sold) |
04-07-2020, 10:06 PM | #15 |
Luckily I took it off last month when I replaced the steering shaft, the Steering gear box and did my brakes. It was a pain to get off. I just let it soak for a bit and was very careful with the torch. Cant wait to get all this stuff put on.It's been a long month on this damn oil patch!!!!
04-07-2020, 11:06 PM | #16 | |
All about them K’s
04-07-2020, 11:22 PM | #17 |
My 72 k20 had a home brew 4" for years (ex fire department
brush truck) then I replaced the springs with new 4" springs on all 4 corners. Still has the factory arm. No wear issues at all in 5 years. In fact the only thing replaced was the leaking steering box. An addition of a front stabilizer bar was a good investment though. I made mounts for a 73 up bar not long after the new springs went under the front. I have put a ton of miles on here including a round trip from VA to TX. |
04-09-2020, 07:51 PM | #18 |
Does anyone have pics of stock vs dropped steering arm on the truck? I got a 72 K10 with a 4" lift and I'm assuming its 'stock' but it all looks pretty level, maybe I'm wrong.
04-09-2020, 08:49 PM | #19 |
04-09-2020, 08:51 PM | #20 |
I'm sorry brother, they laid all the rigs down up here too. It will all come back soon. I was very fortunate that I could get a month of work in, lot of my buddies were not as lucky. This camp has been a ghost town the 4 weeks I just spent up here. It's crazy. Hopefully another month everything goes back to normal. Or normal ish
04-09-2020, 10:41 PM | #21 |
here's a pic of what I've been working on. It's a 72 k10 I got a few months ago. Came with a 4" lift and 35 x 12.5s on it. I've replaced the leaky steering box with a redhead and replaced the drag link and added an ORD frame brace so far. I don't know if my arm is stock or not? Just thought I'd throw it up, maybe it will help someone...
04-09-2020, 11:02 PM | #22 |
All about them K’s
Looks like a raised steering arm to me If you’ve got a 4” lift. Your drag link looks pretty level. Compare your lifter angle to my stock angle. (It has a castle nut on the upper end now)
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 Last edited by 57taskforce; 04-09-2020 at 11:11 PM. |
04-10-2020, 10:37 AM | #23 |
Yeew!! Finally something on my truck that the PO didn't mickey mouse and did right!!!!
04-10-2020, 10:48 AM | #24 | |
04-10-2020, 11:56 AM | #25 | |
All about them K’s
