09-02-2019, 09:24 PM | #1 |
Fuel sender
Just checking in with those that have more experience that me.
My fuel gauge doesnt seem all that reliable. I bought a new fuel sending unit from brothers and installed it. My fuel gauge shows about 3/4 full when really full and when. Its at 1/4 left I can only get 10 gallons into the tank. I assume it's a bad fuel sending unit? Or anything else I should check first? I may just live with the issue for a while but wanted to check with the experienced folks first. Its a bone stock 72 GMC Jimmy. |
09-03-2019, 12:40 PM | #2 |
Re: Fuel sender
I could be wrong but i think some sending units have the wrong ohms (newer trucks were different than 67-72s) so the gauge never reads right. Try searching "fuel sender ohm" for some fun reading.
This might be real helpful: https://67-72chevytrucks.com/vboard/...d.php?t=640615 I bought my sender from classicheartbeat - haven't used it yet, but i trust them more than brothers. good luck! Last edited by SeventyOne; 09-03-2019 at 12:41 PM. Reason: link |
09-03-2019, 02:56 PM | #3 |
Re: Fuel sender
So i may have a 0-50ohm variable resistor in my fuel sender instead of a 0-90ohms resistor?
That would suck, but at least i know. There is no one who has built a voltage to current mirror circuit to adjust the currents to similar levels as a 0-90ohm resistance circuit? That seems like it would be relatively easy to do and its just a couple of transistors. Its been 35 years since i last calculated an voltage following current mirror so if someone has a working circuit i would be happy to borrow it... anyone? Last edited by parb; 09-03-2019 at 03:07 PM. |
