09-14-2019, 02:14 PM | #1 |
Worth messing with?
Got a call about a 1990 4x4 flatbed for sale. 1 ton, 454, auto. Find out it is a light duty 1 ton (8600lb gross). Converted to dually with spacers. Has a tilt bed. 195k on the speedo, will not pass the smog nazi inspection. Couple of low compression cylinders. Needs interior work, pretty much trashed being a contractors truck. Trans was supposedly rebuilt about 2 years ago (T400). Engine partially apart, but not too far. I can get to my house for 600 including towing. I'm on the fence on this one............worth it? Thinking about maybe parting it
09-14-2019, 02:36 PM | #2 | |
Questionable
Re: Worth messing with?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-14-2019, 04:03 PM | #3 |
driving is in my blood
The big block is worth $600 by itself if you part it.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
09-14-2019, 09:27 PM | #4 |
09-15-2019, 08:17 AM | #5 |
It won't have good heads (less they were swapped) but the lower end is the same as older big blocks. I had 2 TBI454s that year range and ran awesome. Nothing special, but I'd get it. I want another one lol.
09-15-2019, 05:49 PM | #6 |
Been thinking more about picking it up and parting it. Just have to find the time to disassemble and stash parts away
09-15-2019, 06:30 PM | #7 |
At 8600 gvw, it’s probably a 3/4 ton
09-15-2019, 08:31 PM | #8 |
09-15-2019, 08:38 PM | #9 |
Being a 90 it won't be an HD, they didn't come out till 91.
09-15-2019, 09:32 PM | #10 |
6000-6200 gvw, 1/2 ton
7200 (f44 rpo) 1/2 ton 7200 light duty 3/4 ton 8500-8600 3/4 ton 9200+ 1 ton The 3500hd trucks aren’t 1 ton. They are 15000 gvw. Either way, it sounds like it may be worthwhile. In my opinion, the amount of rust would be a deciding factor. |
09-15-2019, 10:45 PM | #11 | |
09-16-2019, 08:53 PM | #12 | |
For instance, a light 3/4ton uses the same brake caliper as a heavy 1/2. A light 1ton uses the same caliper as a heavy 3/4ton.
09-24-2019, 08:15 AM | #13 |
A light 1 ton (3500) is a single rear wheel @ 9,200 GVW. The dual rear wheel 1 ton (3500) is 10,000 GVW. The 8,600 GVW is the 8-lug 3/4t (2500) and the 7,200 GVW is the 6-lug 3/4t (2500) with 14-bolt semi-floater. The 7,200 GVW 1/2t (1500) has the 14-bolt semi-floater.
