Old 09-14-2019, 06:13 PM   #26
Madkidd007
Madkidd007's Avatar
Re: pics of your rpm guage setups...custom or stock looking
Originally Posted by '68OrangeSunshine View Post
So diesels require a special kind of tach?
Yes/no. I just haven’t gotten around to it because I don’t actually need a tach. My situation I have everything to wire it, just haven’t. Don’t wanna derail the thread so any questions just pm me
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 09-14-2019, 07:17 PM   #27
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by TBONE1964 View Post
I am not a diesel tech but I know some are cable driven. No electrical. Newer diesel trucks use computer signal.
Thanks. A friend suggested re-engining my '67 K/10 Suburban with a diesel powerplant. I intend to replace the [non-original] 454, but I don't know what I want yet.
Old 09-14-2019, 07:42 PM   #28
'68OrangeSunshine
Right now, I don't have a diesel, so it's not a problem.
I've been saving a set of Autometer gauges, Tach, Vacuum. Oil Pressure and Water Temperature -- to set into the stock Deluxe 7 hole cluster in my '71 GMC Jimmy. I was thinking of having the gauges stick out, like your tach, but I'll still need the stock Speedo/odometer and Fuel gauges. Not sure how that would look with a mixture of recessed and protruding dials...
Old 09-14-2019, 09:45 PM   #29
FirstOwner69
FirstOwner69's Avatar
Mine. Not too unusual.
FirstOwner69 is offline   Reply With Quote
Old 09-14-2019, 09:59 PM   #30
chewychevy67
Had member tbone1964 recalebrate a diesel 4k cable Tach to a 5k cable tack for my 67. He does amazing work. Now the needle looks like the rest of them.
chewychevy67 is online now   Reply With Quote
Old 09-14-2019, 10:07 PM   #31
chewychevy67
Very nice work. Are there numbers above the graduation marks on the small gauges? Maybe I am seeing things. Overlay, rescreen?? Very curious. I am in the works of putting out some overlays with numbers for temp, oil, values.
If you make some for the temperature gauge I would be interested in an overlay.
Old 09-14-2019, 10:16 PM   #32
Jack15T
Active Member
Is that a transmission temp gauge I see in the bottom of the fuel gauge?
Jack15T is offline   Reply With Quote
Old 09-14-2019, 10:34 PM   #33
chewychevy67
Yes it is.
Old 09-14-2019, 10:42 PM   #34
Jack15T
Active Member
Very nice.
Old 09-14-2019, 11:03 PM   #35
Madkidd007
Madkidd007's Avatar
It would look just like this
Old 09-15-2019, 05:18 AM   #36
'68OrangeSunshine
madkid007 -- That could work since I'm more interested in the raw analog data than aesthetics, form, or time/portal regulations.
Old 09-15-2019, 09:14 AM   #37
robs71
robs71's Avatar
our shop truck..Summit brand tach with recall and external shift light.
robs71 is offline   Reply With Quote
Old 09-16-2019, 06:08 PM   #38
Sloonz
Check out Classic Industries G-Stock series gauges. Their gauges match the factory gauges pretty well. Not exact, but blends in with the stock gauges. I was thinking of installing 3-3/8 into the stock location. Sorry for the huge image size.
Sloonz is offline   Reply With Quote
Old 09-19-2019, 10:16 PM   #39
yysenhimer
My setup
yysenhimer is offline   Reply With Quote
Old 09-20-2019, 08:42 AM   #40
toolboxchev
Yes it is.
I did not know about this? Bringing it back up, how did you acquire this setup? I would be interested in any knowledge you have about the trans temp gauge setups.
toolboxchev is offline   Reply With Quote
