09-15-2019, 03:38 PM | #1 |
"Tail Gate Best Seat In House"
A story I just read ,,believe it or not
We had a Chevrolet minivan towed home by AAA. After he dropped it off, he asked what's wrong with it? I told him that it acted like no fuel.
He walked back to his truck and brought a giant, heavy tow hook and crawled under the van. I'm thinking, "what is this crazy old man going to do with that?!" He tapped on the underside of the tank and said, "OK, start it up." I turned the key and it fired right up! I am so proud that I didn't say anything to him while he was dragging that giant hook of death under my van. He said to just replace the fuel pump and you will be good to go. Yep. Do you believe it ,,,,,,,,,,,or not?
When you learn a thing a day you store up smart. |
09-15-2019, 04:12 PM | #2 |
Old member
Re: A story I just read ,,believe it or not
I would check the ground and electrical connections on it first.
Ok, I have a similar story. The other day my friend and I went to check the timing on a car for a friend of his. He checked the timing and while it was running it sounded bad. The owner said after he put the exhaust on it it started running bad. My friend turns and looking for something he picks up a 3' rod and start's to act like he is gonna hit the top of the motor. The owner eyes popped out like what you gonna do! My friend tapped the EGR valve a couple of times with it and it went to running better. He told him to take it off and clean it real good. I was laughing so hard I couldn't stand it. I wished I'd had my phone with me I'd gotten a picture of the owner's eyes!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-15-2019, 04:12 PM | #3 |
BlahBlahBlah
We had an Astro van we did that with. Worked great for quite awhile, why replace its working fine. Died for good when we were in Ocean Shores, a million miles from home.
09-15-2019, 04:59 PM | #4 |
The windings burn up and loose continuity in the pump. Jarring it sometimes gets them touching again. That’s my first step to get one in the shop before we push it in. Sometimes it works, sometimes it doesn’t.
09-15-2019, 05:02 PM | #5 |
Robert Olson Transport
this is a test for anything with an electric fuel pump my son did this for two weeks until he got a paycheck to get around
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
09-15-2019, 05:30 PM | #6 |
I absolutely believe it. I also believe that it might not work a second time.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
09-15-2019, 05:36 PM | #7 |
Roadtrip!
I believe it. I have done it before also. Sometimes just the palm of your hand is enough to get it working for awhile.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
09-15-2019, 06:36 PM | #8 |
blood type; Retumbo
I use a dead blow rubber hammer. We call it a "GM fuel pump reset tool". The brushes get work and they stick in the slides. When it is shut off they cool down and no longer touch the commutator. Tapping bottom of tank jars the brushes loose to make contact again. Same thing can be done on an alternator. Not charging? Tap rear housing near brushes and listen for the typical "whine" when it starts working again
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-15-2019, 08:46 PM | #9 |
We do this al the time so we don't have to push the truck into the shop.
09-16-2019, 06:39 AM | #10 | |
Anything is a GM fuel pump reset tool if you are brave enough. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
