09-14-2019, 02:34 PM | #1 |
black Car Sound Deadening Mat
Does anyone know where you can get Black Car Sound Deadening Matting?
Thanks Rick |
09-14-2019, 04:27 PM | #2 |
Re: black Car Sound Deadening Mat
09-14-2019, 08:38 PM | #3 |
I have looked at that product but have not bought it.Has any one here used it and did it work well?
68' with no bells or whistles unless I add'em. |
09-14-2019, 10:42 PM | #4 |
looked at it too hoping someone has used it too
09-14-2019, 11:52 PM | #5 |
I have used the Noico from amazon, good product, great price. See my crew cab build thread, used it a few months ago.
09-15-2019, 01:43 AM | #6 |
GM Addicted
I don’t like having or using asphalt based products on vehicles. Smells like roofing material. Removed the old product and installed second skin sound solutions damplifier pro. Great US made product.
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
09-15-2019, 05:45 AM | #7 |
54caddy,
How much sq ft did you use in the picture and how come you did not cover all of the metal and did you find a source that sells it cheaper ? |
09-15-2019, 03:27 PM | #8 |
GM Addicted
I used the bulk pack. I used all but 1 sheet. Still need to do inside of doors. And full coverage is not necessary but I tried too. Inside of corners of cab are covered as well. Since tank was removed for audio system going in concentrated on back wall and floor as much as possible.
09-15-2019, 06:00 PM | #9 |
Did the bulk pack have enough for your doors also ? what about higher up the fire wall , did you have enough for that or did that 22 sheets only cover what you showed in your picture ?
09-15-2019, 07:06 PM | #10 |
I used a whole box in my truck , I like it.
09-15-2019, 07:18 PM | #11 | |
why?
09-16-2019, 02:01 AM | #12 |
GM Addicted
Dry ice method to remove the old fat mat.
09-16-2019, 02:06 AM | #13 |
GM Addicted
No need to order more to do inside of doors. Truck has no headliner so nothing was put their, and didn’t go higher up on firewall because customer didn’t want to see it past the carpet. It’s 22 sheets but the sheets are smaller in size than most companies sheet sizes. I actually preferred this size better.
09-16-2019, 10:00 AM | #14 |
My install, helped with the heat also.
09-16-2019, 11:06 AM | #15 |
54Cad,
I am also curious about the Dry Ice, does that cause the glue to harden and crack and release or does it cause the old product to shrink and release from the floor pan???
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
09-16-2019, 12:56 PM | #16 |
GM Addicted
Laying it out like shown in pictures worked but best method was leaking it in bags and allowing it to stay in one spot. It allows the old product to harden and release. It was dry ice with alcohol. When I purchased the second skin I talked to them and they gave me these tips to remove old product. Once it was all off cleaned it with acetone then with denatured alcohol made the surface really clean and to ensure proper adhesion of the damplifier pro. A lot more info on this when i did it on InstaGram
09-16-2019, 01:59 PM | #17 | |
