Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 10-29-2019, 01:13 AM   #701
cwcarpenter98
cwcarpenter98's Avatar
Re: Our "What are we going to do?" 66 Suburban Build
Originally Posted by RockTonka View Post
If you were closer, I'd make you a deal on my old one...shipping probably isn't worth it.
That would be sweet, but I agree, shipping would be way too much. I'm sure I can find a bar somewhere around GA. There's a few places that I need to go to, just haven't had the time this semester to do so
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 10-29-2019, 01:01 PM   #702
likaroc13
Rollin' Old Skool
Glad to hear it's back together & running! Hopefully it all continues to work well from here on out. I know y'all are ready to just enjoy the fruits of your labor. Any thoughts yet on the headlights? I've noticed lots of folks switching to LED headlights these days, even on more modern (but not new) stuff.
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 10-30-2019, 08:28 PM   #703
RockTonka
RockTonka's Avatar
Preliminary thoughts on lights are that they are fairly bright, low beam is the upper half and high beam is upper and lower at the same time...with that said, I haven't been out at night with them yet.
We'll see how long they last...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 10-30-2019, 09:14 PM   #704
piratexpress1369a
piratexpress1369a's Avatar
Sounds awesome glad you are out driving and enjoying it
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 10-30-2019, 10:00 PM   #705
RockTonka
RockTonka's Avatar
Thanks PE!
My build thread
Old 11-02-2019, 08:21 PM   #706
RockTonka
RockTonka's Avatar
My build thread
Old 11-02-2019, 08:27 PM   #707
RockTonka
RockTonka's Avatar
All LED is fairly bright!
First pic is low beam, second is high...then back-ups and interior.
My build thread
Old 11-16-2019, 07:41 PM   #708
RockTonka
RockTonka's Avatar
Got a few new parts in from Porterbilt for the front end...
My build thread
Old 11-17-2019, 12:36 AM   #709
Captainfab
60-66 Nut
Nice
Old 11-19-2019, 09:35 PM   #710
cj847
cj847's Avatar
Did you not make it to Sema? I voted a lot.
cj847 is offline   Reply With Quote
Old 11-20-2019, 12:52 AM   #711
RockTonka
RockTonka's Avatar
Nope, not even top 5 from what we understand!
Thanks for the votes though!
My build thread
Old 11-30-2019, 03:00 AM   #712
RockTonka
RockTonka's Avatar
Picked up front end parts from powder coating and starting the tear down...
My build thread
Old 11-30-2019, 04:10 AM   #713
piratexpress1369a
That is awesome
63
Old 12-01-2019, 02:52 AM   #714
RockTonka
RockTonka's Avatar
That is awesome
Thanks PE, this will improve the handling a bit and more importantly (for us), the arms will move the wheel centerline forward an inch. We need a smidge more clearance on the driver side header.
Everything came apart nicely...new upper shock mounts got welded on (couldn't get to the backside with boxed frame).
We're going to order in some heavier front springs...the stockers, although relatively new, are a little overwhelmed with the added weight up front.
My build thread
Old 12-01-2019, 04:20 PM   #715
likaroc13
Rollin' Old Skool
Nice! Definitely need all the good handling you can get with a beast like that.
Phillip
My Build threads:
Pics:
Previous Rides:
Old 12-15-2019, 04:30 AM   #716
RockTonka
RockTonka's Avatar
It can't hurt!
We ended up working with Eaton Detroit Spring for different front springs, these guys know their sh!t...wealth of knowledge for sure.
I measured my existing springs at 0.79" dia. and 13" long free length. This is a little heavier than stock C10. Eaton recommended a 0.815 dia. at 12 5/8" long...jumping me from a roughly 800lb/in to 1000lb/in spring rate and keeping my ride height exactly the same.
They had these springs in stock and shipped out the same day I called.
The new springs are the clean ones...can't tell much difference side by side, but I can tell a big difference installed.
We also got the Porterbilt arms installed tonight (quick note about superior customer service...texted Nate with a question on the installation and he answered within a few minutes late on a Saturday afternoon).
Moving the wheel centerline forward an inch is a subtle difference, but noticeable and provides us with needed clearance.
My build thread
Old 12-15-2019, 07:03 PM   #717
RockTonka
RockTonka's Avatar
Buttoned back up...
My build thread
Old 12-16-2019, 12:02 AM   #718
likaroc13
Rollin' Old Skool
Looks good! Always a huge plus when you get good customer service. Some companies need a good lesson in that!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 12-17-2019, 10:26 AM   #719
piratexpress1369a
How is the ride with the new springs
63
Old 12-18-2019, 12:57 AM   #720
RockTonka
RockTonka's Avatar
Good, you can tell that it's a little bit stiffer...we're feeling small bumps, cracks, RR crossings, and whatnot more. But, it's more planted and doesn't compress nearly as much as before over larger bumps/swells.
We took the burb to a friend's shop and got the front-end aligned. Nate wanted to see camber at 0, caster at 5, and toe in at 1/8 per side...the UCA studs weren't long enough to stack the amount of shims needed to get there.
See pic below for where we ended up at.
It seems to drive well, but we'll probably work on getting longer upper arm studs in at some point.
My build thread
Old 12-24-2019, 01:25 AM   #721
hemifalcon
I just went back and reviewed your build thread.. It's pretty awesome the stages of progression you guys went through with the truck.. Keep it up!
My '65 Suburban Resto build--
http://smg.photobucket.com/albums/v6...65%20Suburban/
And it's story of being 'saved'
http://www.jalopyjournal.com/forum/s...d.php?t=631495
hemifalcon is offline   Reply With Quote
Old 12-27-2019, 02:03 AM   #722
RockTonka
RockTonka's Avatar
Thanks! We're gonna keep it like it is for a while.
My son commisioned an original painting of the burb by Studio-66 Hot Rod Art (Gene Chambers) in Utah. I had a chance to talk to him a bit at the SLC show we went to in September and was really impressed by what he was doing...check him out at www.studio-66.com.
My son and his girlfriend surprised me with it at Christmas...I absolutely love it!
My build thread
Old 12-29-2019, 11:12 AM   #723
piratexpress1369a
Awesome Christmas gift
63
Old 12-31-2019, 10:02 AM   #724
likaroc13
Rollin' Old Skool
Great piece of artwork!
Phillip
My Build threads:
Pics:
Previous Rides:
Old 03-02-2020, 06:49 PM   #725
joe dirt
joe dirt's Avatar
just went thru this build....wow...great work!...that thing sure did snowball
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
