Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 10-22-2021, 09:31 AM   #1
58CameoAZ
Seam Sealer ?
What is a good seam sealer to use? I need to do the top of my rain gutter
on my cab and inside the step area of the cab also, looking for suggestions.
Thx,Allen
58CameoAZ is offline   Reply With Quote
Old 10-23-2021, 06:57 PM   #2
SkinnyG
SkinnyG's Avatar
Re: Seam Sealer ?
Many folks use a self-leveling 2K seam sealer for horizontal areas like the drip rail. I haven't done it yet.
I did the underside of my cab in ordinary SEM 2K Seam Sealer. No complaints.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 10-26-2021, 04:08 PM   #3
theastronaut
theastronaut's Avatar
Re: Seam Sealer ?
Self leveling is what you want for drip rails, it will flow and level out to a glass-smooth finish that only needs scuffing before sealer/paint. It's too thin for normal seams so you'll want a normal seam sealer for that. Two part sealers are best, they won't shrink later. I like Fusor 122ez for drip rails and SEM 39377 for other seams.
theastronaut is offline   Reply With Quote
Old 10-27-2021, 09:11 AM   #4
lupo
Re: Seam Sealer ?
After you remove the old seam sealer I would suggest a good acid etch prior to priming. Soak the seam for a day or two. Use a paintbrush to apply to metal prep into the drip rail. After it dries prime it, and go from there.
lupo is offline   Reply With Quote
Old 10-27-2021, 10:19 AM   #5
58CameoAZ
Re: Seam Sealer ?
Well, i Media blasted the whole cab clean and preped and sprayed Skueegs Hotrod Epoxy primer over my entire cab. Everything was super clean!
Allen
Old 10-27-2021, 10:21 AM   #6
58CameoAZ
Re: Seam Sealer ?
I will check into this! Thank you very much!
Allen
Old 10-27-2021, 10:24 AM   #7
lupo
Re: Seam Sealer ?
Very good
Old 10-27-2021, 10:30 AM   #8
58CameoAZ
Re: Seam Sealer ?
Question ? Using the Fusor & SEM Products do i need to buy two seperate Caulking guns
OR, will the SEM 71119 Caulking gun work for both? Suggestions?
Thank you again!
Allen
Old 10-27-2021, 09:19 PM   #9
HAULIN' IT
Re: Seam Sealer ?
Fusor is in the "change-over" phase to the smaller tubes like the SEM. as long as you purchase the new short Fusor tubes you will be good. Lorne
HAULIN' IT is offline   Reply With Quote
Old 10-28-2021, 09:28 AM   #10
Grumpy old man
Grumpy old man's Avatar
Re: Seam Sealer ?
Eastwood seam sealer uses a regular caulking gin . Your cab has to be level and
the self leveling sealer sets up fast so you need to be ready to do it all in less than 5 minutes . if you use masking tape be ready to remove it as soon as possible once the sealer sets the tape will be very hard to remove
https://www.youtube.com/watch?v=_yCa9zzkMvo
http://67-72chevytrucks.com/vboard/s...=783262&page=2
https://www.eastwood.com/ew-2k-self-...cartridge.html
https://www.youtube.com/watch?v=CbuvdY0lzTg
Watch all the stout customs videos . https://www.youtube.com/c/StoutCustom/videos
Old 10-28-2021, 03:38 PM   #11
wazzabie
Re: Seam Sealer ?
How is 3M seam sealer?
wazzabie is offline   Reply With Quote
