01-16-2021, 10:14 PM | #1 |
Accident/damaged suspension parts
I slid on some black ice and nailed my right wheel, which is trashed.
Took wheel off and looked at damage. I was only doing 15 mph when I hit the concrete divider. Outer tie rod okay, inner bent about 12-15 degrees. Center link looks bent as well. Does anyone know where I can find a centerlink for my 1 ton Scottsdale? I've looked on internet, but am having a hard time finding a centerlink that the seller confirms will fit. Thanks! |
01-16-2021, 10:31 PM | #2 |
Re: Accident/damaged suspension parts
Oreillys carries all kinds...what yr?...
01-17-2021, 06:52 AM | #3 |
Next!
If its an 81-86 K30 I've been using Moog DS-905 with success.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
01-17-2021, 10:30 AM | #4 |
When I slid into a curb once I bent my lower control arm. You might want to look that over too. (15 mph? ok lol)
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-17-2021, 06:52 PM | #5 |
01-17-2021, 06:52 PM | #6 |
01-17-2021, 06:53 PM | #7 |
01-17-2021, 08:30 PM | #8 |
01-18-2021, 10:53 AM | #9 |
Center links are a non wearable item & usually need to be sourced from a used vehicle of the same build type (C10, 20, 30 etc...).
C10 vs C20/30 a-arms are different as well as far as bushings & BJ sizes. If you need to replace one of them keep it in mind. Tie rod ends are an easy replacement through the local auto parts or an internet source.
01-19-2021, 06:39 PM | #10 | |
Now, can you spread the word I need a C30 center link? Thanks! Wayne |
01-19-2021, 07:08 PM | #11 |
$90 at Oreilly's in mongo's link above
01-19-2021, 08:47 PM | #12 |
It only has original paint once |
01-20-2021, 01:15 PM | #13 |
01-20-2021, 03:39 PM | #14 | |
I searched there for you but apparently Summit doesn't carry the 'Rare Parts' brand.
01-23-2021, 01:16 PM | #15 | |
Unfortunately, Auto etc, and O'Reilly's, and ad nauseum... had no stock on this center link. Thanks anyway, folks. I took it to someome who straightened it. |
01-23-2021, 02:29 PM | #16 |
Glad you figured out a solution.
