Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 09-25-2020, 12:31 PM   #1
kglowacky
candidate for a window relay ???
Just finished installing my windows. New regulators. new motor. pass Window goes up and down good with the used rubber installed. Installed used rubber on drivers side and about 3/4 of the way up it struggles and stops short by 1/2 inch.( I can push it with the motor help and it will go up. Is there any adjustment ibn the way it rolls up in the channels? Will a relay help me? Thinking rubber is the issue and going to reinstall. Without rubber window goes up and down perfectly. Anyone had success in trimming the rubber? Not a show truck just a daily driver. not sure on adding relays.. Also going to see if I can slide the regulator a little one way or another as there was some body work done around the four regulator holes.
kglowacky is offline   Reply With Quote
Old 09-26-2020, 06:57 PM   #2
kipps
Re: candidate for a window relay ???
Can you remove the door panel, and back-probe the motor connector to watch for voltage drop during operation?
Alternately, find another motor connector, and run large wires(12 gauge?) straight to the battery for a temporary test. Bypass any switches and connectors enroute. If this experiment significantly changes performance, then yes, a relay should help.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome!
kipps is offline   Reply With Quote
