08-01-2020, 01:34 AM | #1 |
Electrical Oil Pressure Gauge
Anybody out there know what year GM started putting electrical oil pressure gauges in their trucks?
Thanks!
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
08-01-2020, 05:26 PM | #2 |
Re: Electrical Oil Pressure Gauge
73 and up. Pretty sure 72 was the last year for mechanical gauges. Might be an exception in some heavy duty trucks.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
08-01-2020, 09:35 PM | #3 |
Thanks. I'll be hitting the wrecking yard Tuesday. This will save me some time.
08-29-2020, 01:09 PM | #4 |
79-80 I be leave was the.
as 76-77- mechanical gauge
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
