Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-24-2020, 08:53 PM   #1
3x2GTO
Defective wiper switch?
On my 85 silverado, whenever I turn the key to the run position, the wipers cycle 3 times and return to their park position, they also cycle on a rough gravel road. When turned on manually, they work fine on all speeds except intermittent, which doesn't work. I installed a tested wiper motor, but no luck. Bad switch?
3x2GTO is offline   Reply With Quote
Old 08-24-2020, 09:10 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Defective wiper switch?
Kinda sounds like it..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 08-25-2020, 07:56 PM   #3
3x2GTO
Well 2 hours and $115 and the new switch is in, but the problems still exist, every time the key is turned to the on position the wipers cycle in wash mode, usually 3-4 sweeps, also repeated when driving or at idle. But, attached to the underside of the column is the wiper delay module, more a less a small square box with a heat sink. I gave the module several hard raps with a screw driver handle and everything instantly worked as it should, problems gone. I'm going to pull another module from my parts burb to replace the one on my truck. Hopefully this will save someone else some time and $$$.
Old 08-29-2020, 03:28 PM   #4
3x2GTO
I ran the truck about 30 minutes today, wipers would do 1 sweep on their own about every 5 minutes, so I changed out the delay module with a good used one. I drove the truck about an hour and everything works as it should, finally ready for inspection!
Old 08-30-2020, 07:54 AM   #5
JA50N
Do they make these new? My wipers don't work on intermittent and also don't park and I think this is the culprit.
JA50N is offline   Reply With Quote
Old 08-30-2020, 06:05 PM   #6
3x2GTO
LMC has them
