07-12-2020, 05:05 PM | #1 |
*Volt Meter Drops Below 13 Volts*
It started pouring down rain today so my yard project came to a halt. I made a trip to Harbor Freight and picked up a multimeter just to see what my charging system is doing as my in-dash meter (Classic Instruments) was showing below 13 volts at times with the AC on. This time the meter showed about the same as the multimeter. It never dipped below 13 volts. Probably need to check it next time I see it drop below 13 volts to see if its the gauge which I suspect or my charging system. What do you guys think about the numbers I'm seeing?
Pic #1 - Engine running, electric fuel pump, and electric fan Pic #2 - Engine running, electric fuel pump, AC on with blower on high Pic #3 - Engine running, electric fuel pump, AC on with blower on high, radio on, headlights on
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 07-13-2020 at 06:57 AM. |
07-12-2020, 06:41 PM | #2 |
Re: *Volt Meter Drops Below 13 Volts*
I only see one picture, but nothing is wrong with any of those 3 voltage readings, charging system is keeping output voltage well above battery voltage..
07-13-2020, 07:36 AM | #3 |
Moderator
I'm wondering where you're sensing wire is attached?
07-13-2020, 12:48 PM | #4 |
Msgt USAF Ret
I agree and where you take your readings is important too. you want to check voltage at the load to see if you are getting plus 13 at the main junction. You say you've seen below 13 with the accessories on. its important how your alternator output wire is ran too. if you've run it directly to the battery positive, you might not get full voltage to your accessories.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
07-13-2020, 06:45 PM | #5 |
Thanks guys. Not sure where the sending wire is attached. That may be something I need to check out. My readings where taken at the battery. All I was looking for was to see if there were any readings below 13 volts. Before I took these readings I was thinking the in dash gauge was maybe off a little.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck |
07-13-2020, 08:06 PM | #6 |
Old member
Where the readings took with the motor just idling are reved up? If it was just idling rev it up and see how they read. If they go up a little I see nothing wrong with it. If it drops below 13 every now and then it could be the AC cycling on/off causing it while under a heavy load. If it only drops for a few seconds I wouldn't be to worried. I see nothing wrong with it as is.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
07-17-2020, 04:59 PM | #7 |
Thought I would recheck the charging system again today in hopes of seeing the in-dash volt meter reading below 13 volts and it did. I wanted to make sure I'm still getting good reading across the battery while the in-dash meter is showing low. I feel better now. I was afraid the wife and I would drive somewhere and get stranded with a dead battery. Whatya think of these reading on the multimeter vs the in-dash meter? I don't know if there is any way to adjust the in-dash meter as sometimes it reads correct and some times it's a little off as the pic shows.
07-17-2020, 07:08 PM | #8 |
Is it possible to take a voltage reading on the terminal post of the meter itself and compare it to the reading on the dvm?? Varying voltage indications on the dash meter could be due to varying loads that affect the actual charge voltage..
07-17-2020, 08:54 PM | #9 |
Can't get to the back of the meter. I'm just Glad the reading across the battery is not below 13 volts. The battery that was in the truck when I got it was about 5 years old so I'm guessing the PO wasn't having any battery issues.
If you can't fix it with duct tape, it's an electrical problem. 1949 5 Window 3100 https://zippi6.wixsite.com/adtruck Last edited by Zippi; 07-18-2020 at 06:49 AM. |
07-28-2020, 06:54 PM | #10 |
Too duplicate the meter reading you need to measure from the same points
Measurements from different will cause difference in readings as wire lengths and load differences in different spots will vary the readings And a 20 dollar harbor freight meter are not that reliable it will give you a ball park reading but will not be as accurate or quickly reponsive as a Fluke meter |
07-28-2020, 09:51 PM | #11 | |
Fluke 117/323 Electricians Combo Kit, Digital Multimeter and Clamp Meter https://www.fluke.com/en-us/product/...ke-117-323-kit -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
07-29-2020, 07:00 AM | #12 | |
07-29-2020, 08:18 AM | #13 |
I am not saying buy the good meter you need to understand a cheap meter is more a good ball park and may not have fast resolution for an instant reading
A good test i found on a truck for how fast a meter reads is test your trailer receptacle with a meter I have a 800 dollar meter from the snapon guy that fails this test |
07-29-2020, 10:57 AM | #14 |
Moderator
My mother in law bought me a Fluke for Christmas a few years ago, I never looked back.
08-13-2020, 01:57 PM | #15 |
As others have mentioned, the lower reading at the gauge is at least partly due to the length of wire and how ever many joints are in that wire between the gauge and the battery where you are attaching the meter. It would, IMO, be a waste of time trying to run a heavier direct wire just to try to get the gauge up to what the meter reads.
As someone said, realizing that the gauge reads 1/2-1 volt lower than actual battery voltage should give you enough peace of mind. |
09-17-2020, 04:13 PM | #16 |
Old member
Again no reason to be worried. It could be the AC cycling. It could be a number of things but if it's reading 13 and above you should be ok. Do the lights go dim when you let off the gas. It could be belt slipping even.
Then again it could be the gauge but as stated you would need your meter hooked up where it's connected to see. As long as the battery is getting 13 are more volts when everything is running your fine.
09-17-2020, 09:02 PM | #17 |
As long as the dash guage stays around 13V, and the battery voltage when running is ~13.5 or so I wouldn't worry.
As far as a DMM is concerned, Fluke is great. Mine was last calibrated in 1989. You can pick up a good meter from CL for example for less money. Just make sure you test all functions before buying. |
