Old 10-06-2013, 05:23 PM   #26
LT1 Burb
LT1 Burb's Avatar
Re: Adding body side molding from Mar-K
Looks killer
LT1 Burb is offline   Reply With Quote
Old 01-10-2014, 08:28 PM   #27
Pssst
Pssst's Avatar
That looks awesome! Beats drilling holes if truck did not come stock with moldings.
Pssst is offline   Reply With Quote
Old 02-02-2014, 09:51 AM   #28
rideblue00
rideblue00's Avatar
3M emblem tape part # ???
rideblue00 is offline   Reply With Quote
Old 02-02-2014, 12:21 PM   #29
NEWFISHER
NEWFISHER's Avatar
This is what I used
http://solutions.3m.com/wps/portal/3...beS2Z15RR9ZVgl
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-14-2014, 05:45 PM   #30
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Originally Posted by NEWFISHER View Post
A little bit of tech for those who want side moldings:
You will need:
Table saw
Razor blade
3/4 masking tape
Tape measure
1/4 scrap sheets of clear plastic/acrylic
1/8 scrap sheets of clear plastic/acrylic
3M 1/4 wide .30 or .045 emblem tape
3M 3/8 wide .30 or .045 emblem tape
Alcohol wipes or wax and grease remover.
I used clear plastic so I could see through it to ensure the 3m tape was sticking.
Wipe the sides of the truck down with alcohol wipes or wax and grease remover to clean the surface.
Rip the 1/4 and 1/8 plastic down into strips that will fit inside the moldings. Remove the protective paper and wipe both sides with cleaner. Wipe the insides of the moldings with cleaner.
This is the smaller molding, the larger was a breeze. Lay it upside down, clean with alcohol and apply the 3M inside the back of the molding.
Here it is "loaded" with the plastic spacer. You can see through the plastic to ensure the 3M is adhering to the plastic.
on edge showing the thickness-just barley visible and enough to stick, but not show the tape when installed.
Lay a second strip of 3M on top of the plastic strip so you have :: molding, 3m, plastic strip, 3m . Wait to pull the red plastic backing until you have measured the sides of the truck. I started with the larger molding on the door. Measure 1 1/2" down from the body crease and mark with masking tape at both ends. Peel your red film from the molding and line up one end with your tape. Be very carefull to only stick the very edge of the molding as you get one chance to do this. Peeling them back off will damage the molding! Use a second set of hands if needed. Now line up the other end and apply pressure across the face of the molding with your palm. They are very delicate so you don't need much pressure, just enough to get the tape to stick across the whole length.
I started with the door because it was the shortest , easiest to deal with and measure by myself and I could stage the others from each end of the door molding if I knew it was 100% correct. The smaller moldings start from the door also and they sit 1 1/2" below the large molding. Once you have the large moldings installed, start with the small door molding. Slip the forward tip under the large molding and work back towards the rear of the truck. Set the back of the taped molding at your masking mark and apply pressure.
I waited until I had the long moldings installed before installing the cab corners in case I had a visual difference in cab or bed mounts that would throw off the measurements, I could fudge the continuous look with the smaller cab ones. It all worked out and they are straight as an arrow. Nice product from Mar-K and no holes drilled in the body. If you ever have to pull one off you can use 10lb fishing line wrapped around both index fingers like dental floss and "saw" the 3M from behind with the fishing line and it will not damage the paint. pulling them will only damage the moldings.
Buddy
Sick5 is offline   Reply With Quote
Old 02-15-2014, 02:20 PM   #31
factorystock
factorystock's Avatar
needs something to break up all of the single color.
Like the transformation! A fawn interior will be the icing on the cake.
factorystock is offline   Reply With Quote
Old 05-12-2014, 04:43 PM   #32
Grizz1963
Grizz1963's Avatar
Rather than start another thread......
I have a Short Fleetside which needs all the side trim to be replaced when I do the body and paint.
I was wondering if there are distinct knowledge, or experience about who makes the best quality side trim.
I seem to recall there was trim that would damage or dent when being fitted.
All advice and opinions appreciated.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 05-13-2014, 09:09 AM   #33
LT1 Burb
LT1 Burb's Avatar
I would just deal with Mark-K , they are reputed to be the best. I bought a set from them last year but have yet to open the tube.
Old 05-13-2014, 09:13 AM   #34
Grizz1963
Grizz1963's Avatar
Hi mate
Thanks for the reply.
You made me laugh here in Starbucks where I am having a coffee and sandwich before going out to work again.
I have stuff in boxes too that is unopened.
Do you have a link for Mar-K as I Googled but could not find them.
Whooooops !!
Edit. Just seen you did say Mark-K and I Googled Mar-K so back to Google.
Old 05-13-2014, 09:26 AM   #35
racecougar
racecougar's Avatar
Rian,
It's Mar-K. http://www.mar-k.com/Catalog/catalog.aspx
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 10-30-2014, 07:59 PM   #36
Ratpin
Ratpin's Avatar
Nice write up Newfisher!
"It ain't as easy as Chip Foose makes it look"
Ratpin is offline   Reply With Quote
Old 10-30-2014, 11:50 PM   #37
CRGRS 66
CRGRS 66's Avatar
great write up! I have saved this thread for future reference
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 10-31-2014, 06:39 AM   #38
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Hey, you're missing a lug nut on the left rear!
Oh! Great write up!!!
Steve
1997 Tahoe LT 4D 2WD (DD)
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-31-2014, 08:05 AM   #39
Clyde65
Clyde65's Avatar
Nice write up! Ill be doing this on my truck some day!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-16-2018, 11:39 AM   #40
londoncalling
Reviving the thread with a question.
Will the 67-69 trim fit the 70 body?
It looks like it would, but wondering if anyone on the site has actually tried it.
Thank you,
Phil
londoncalling is offline   Reply With Quote
Old 10-16-2018, 11:42 AM   #41
rideblue00
rideblue00's Avatar
You have posted in the wrong year forum? This is 60-66
Old 10-16-2018, 11:43 AM   #42
londoncalling
Sorry guys - I should have made it clear that I'm asking about a Suburban.
Old 10-20-2018, 12:17 AM   #43
66C10LB
The moulding looks great against the orange paint! Big difference...really breaks it up like you said.
66C10LB is offline   Reply With Quote
Old 11-11-2019, 02:59 AM   #44
justincoons71
Can anyone repost pictures? Ornhave any pics of how to use the 3m? I can’t see any of these pics. Thank you!
justincoons71 is offline   Reply With Quote
Old 11-11-2019, 11:23 AM   #45
joe dirt
joe dirt's Avatar
newfisher, where at in Oregon are you? im going to purchase the same trim eventually and may need to look at yours for reference
heres my 64 shorty that really needs something to break up the single color paint, was actually thinking about putting the red inside the trim for a break of color, not sure yet tho
1961 c10 longbed - gone
1964 c10 swb
joe dirt is offline   Reply With Quote
Old 07-14-2020, 01:31 PM   #46
bigmoe
bigmoe's Avatar
Great write up Newfisher! I plan on doing the same to my 65 very soon. Only difference will be I plan to put a strip of white vinyl stripe between the moldings where it should be painted. I'll put the stripe on first, slightly wider to fit under the molding. I thought doing the vinyl stripe would be simpler than trying to get the painter to do the stripe. Just waiting for the box to be painted and installed but I'll post picks when done.
bigmoe is offline   Reply With Quote
Old 08-04-2020, 10:52 AM   #47
88Stanger
88Stanger's Avatar
Awesome write up, exactly what i wanted....
88Stanger is offline   Reply With Quote
Old 08-21-2020, 07:39 PM   #48
bigmoe
bigmoe's Avatar
Great write up! I'm tackling this job this weekend. I also have white vinyl decal to go between the trims. One thing I'm wondering is how did you go about doing the front spear?
Old 08-22-2020, 11:51 PM   #49
painterljp
Subscribed. Have a longbed no trim but want to put trim on it eventually. Sounds like works good. Thanks for instructions.
painterljp is offline   Reply With Quote
Old 08-23-2020, 04:38 PM   #50
bigmoe
bigmoe's Avatar
Got my trim3M'd on. Overall it was pretty straight forward. Just one blip when my helper got over zealous and one piece stuck down crooked. Just used to fishing line to floss it off and start over.
I had inquired about the front spear a couple of post up. My trim set from Mar K came with hardware so I used the clip and drilled a hole. I used a cu tip to paint the hole. It was a bit loose at the joint end so I used 3M there. (
Sorry about the upside down. I flipped the iphone over this time and it still didn't work)
