11-09-2012, 07:11 PM | #1 |
Headlight trouble
Last night my low beam didn't light the way to go home ! The side marker are ok
The hight beam ok but no light with low beam . Since few days i smell a " burn odor " with hight beam on . Is it a rotten headlight switch ? Rotten relay ? Thanks for your help . Posted via Mobile Device |
11-09-2012, 07:31 PM | #2 |
20' Daredevil (Ret)
Re: Headlight trouble
I assume both low beams failed, and both high beams worked? I would suspect the dimmer switch on the floor. It's not uncommon to fail and pretty easy to replace. There's no headlight relay unless you added one (which is a great idea).
BTW, welcome to the boards!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-09-2012, 07:34 PM | #3 |
11-10-2012, 05:43 PM | #4 |
Will check it , thanks Phil
11-10-2012, 05:47 PM | #5 |
11-10-2012, 05:49 PM | #6 |
Oups !
11-10-2012, 05:53 PM | #7 |
Had the same problem couple days ago, I just replaced headlights and external voltage regulator.
No problems thus far amigo Posted via Mobile Device
WITNESS Dont be like me be better than me |
