Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-23-2019, 01:04 PM   #1
Stranded in middle nowhere, 1987/350 manual ECM fuze blown
I had another fuze in the truck, plugged it in and it blew...
Any ideas to get me back on the road?
Thanks!
Old 08-23-2019, 01:08 PM   #2
Andy4639
Old member
Andy4639's Avatar
Question Re: Stranded in middle nowhere, 1987/350 manual ECM fuze blown
Sounds as if you have a straight to ground issue.
Which fuse is it?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-23-2019, 01:21 PM   #3
ECM 1 fuze
Old 08-23-2019, 01:41 PM   #4
Wonder if I pull the 30 amp accessory fuze I might get lucky and it will start? Only have one fuze left
Old 08-23-2019, 02:18 PM   #5
Found it after much searching, a frayed wire at the injector area.
Old 08-23-2019, 03:54 PM   #6
You nailed it
Which fuse is it?
Old 08-23-2019, 09:45 PM   #7
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
what size was the original? 10a....
if it was 30, I'd say why not... never put a larger amp fuse in place of one that's instantly blowing, your asking for a much bigger problem than you had such as a fire. even if its just to get you home...
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 08-25-2019, 11:09 PM   #8
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Stranded in middle nowhere, 1987/350 manual ECM fuze blown
You nailed it
Glad you found it. Sorry haven't been on the computer in a couple of days. Had no internet.
Old 08-26-2019, 05:14 PM   #9
clint
ECM 1 is a 10 amp, I was only going to pull the 30amp to see it affected the short, not use it in place of a 10 amp.
