Old 06-08-2022, 03:03 PM   #1
3QTRTONS
3QTRTONS's Avatar
Mix&Match Burbs?
So,,,
I have 2 Suburbans:
1976 K20 350/THD400 (I believe)/NP203/ Barn Doors
1984 K10 35/THD350/NP208/ Tailgate
What I'd LIKE to do is swap the '84 onto the '76
BUT end up with the barn doors on the '84
ANYONE done this?
Guidance?
Opinions?
1994 C1500 rclb 1988 C1500 rclb
1969 ES5500 B E A S T 1983 C10 'farm truck'
1976 K20 Suburban 1984 K10 Suburban
1981 Jeep CJ5/350 Vortec
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 06-12-2022, 08:27 AM   #2
Corts60
Just here to tinker
Corts60's Avatar
Re: Mix&Match Burbs?
I would think you’d be able to pull this off. Just swap all the hardware and backing plates for the barn doors to the other body. All the right holes should be there to line everything up. You may have to figure out the courtesy light switches/circuit though as I’m sure it’s in a different spot on the tailgate units.
Old 06-13-2022, 08:24 AM   #3
v30crewcab
v30crewcab's Avatar
It can be done but the lower sill plate is different between the door styles. it can be swapped but its a bunch of work and welding. I have one I plan on doing that to at some point.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
