Old 09-18-2020, 11:09 AM   #23
skyphix
Re: Wheel Vintiques fitment
Originally Posted by Robzkombi View Post
Okay so after getting the 235/75/15 wheels mounted to the OG 15 inch wheels and installed on my truck I did have a small issue with grinding. i purchased a 1/4" spacer and although it did minimize the grinding, there was still a slight rub. Turns out it was the clip on wheel balancing weights that were the issue. Went back to Discount Tire and had them re-balance the wheels this time using the stick on weights and that took care of the issue, i'm now a happy camper/trucker.
I had the same issue with Rallyes and wheel weights. They did self clearance on my 1600 mile drive, but I also did run a spacer. I was already using stick on wheel weights unfortunately. Glad you got it worked out!
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
