Old 01-27-2018, 10:15 PM   #1
69SCSS
69SCSS's Avatar
Upgrade my stock 350 for torque.
My '68 has a 195/260hp GM Crate Engine from 2013 in it. I swapped on a Performer Intake and 1405 carb. It runs good, gets OK mileage, pulls well, hell even spins the tires occasionally. I did a quick GPS 1/4 mile test and it did a high 14 at about 85. Not bad, really. But.... I want it to pull harder.
My real world expectation... I don't really go over 4k rpms, ever. So torque is way more important than hp. I want to upgrade the long block with a cam / lifter kit that will maximize low end torque, and if it runs out of steam at 4500, no worries. I have stock ramhorns and pretty happy with how they sound and work.
I looked at a COMP grind SK12-206-2, (https://www.summitracing.com/parts/cca-sk12-206-2) that seems good. I also saw the COMP CL12-210-2 (https://www.summitracing.com/parts/c...10-2/overview/) that seems good, but not sure that it might be too much for my small stock iron heads. I want to keep with in budget, so $250 for a cam swap is about right. Anyone have any experience with either of these or similar spec grinds for torque?
My 68 SWB
Al Silveira Music
<- My daughter loves this guy 8-)
69SCSS is offline   Reply With Quote
Old 01-27-2018, 10:49 PM   #2
nikwho
nikwho's Avatar
Re: Upgrade my stock 350 for torque.
I've put the Summit Racing 1103 cam in two 350's now and could not be happier. I currently run that cam with one of the cheap Summit Racing torque converters (2,300-2,600 RPM stall) and could not be happier. I run it with Vortec heads and a Weiand Stealth (two plane, like your Performer) intake and a 1406 Edelbrock carb. That truck weighs 3,640 lbs curb weight, without me. Cam broke in perfectly, even with a couple of hiccups during the break in process. The 1103 cam reports a power range between 1,600-5,200. If that is a little higher than you want your power band to be, the 1102 cam from Summit looks good and has good reviews. It's power building range is reportedly between 1,500-4,000 RPM. Either way, I don't think that you can beat those cams for the money, each priced at $62, or $100 for the kit that includes new lifters, which you will NEED when swapping your cam.
Good luck!
Nik
'59 Apache - 383" SBC/TH-350
'68 GMC - BBC/TH400
nikwho is offline   Reply With Quote
Old 01-27-2018, 10:53 PM   #3
B. W.
B. W.'s Avatar
The 440 lift cam will give you better low end performance.
B. W. is offline   Reply With Quote
Old 01-27-2018, 10:55 PM   #4
nikwho
nikwho's Avatar
I think that you're doing REALLY well if you're already getting that thing 1320' in 14 seconds from a stop, with an otherwise stock engine and transmission.
'68 GMC - BBC/TH400
Old 01-27-2018, 11:12 PM   #5
69SCSS
69SCSS's Avatar
Pretty light truck, no power steering, 3.73 gears and 700r4 setup for higher shifts. It was a 14.9, but that is a GPS run, so it could be a 15.2-14.6. Not bad like I said, not great though.
The 440 cam does sound better. The 260 duration should keep the torque peak lower. 278/288 seems high. My cam is a puny 194/204 @ .050 right now at like .400" lift... so any of those will wake it up!
My 68 SWB
Al Silveira Music
Old 01-27-2018, 11:28 PM   #6
nikwho
nikwho's Avatar
The 700r4 will certainly help, with the lower first gear!
'68 GMC - BBC/TH400
Old 01-28-2018, 12:38 AM   #7
69SCSS
69SCSS's Avatar
Yea, it has the usual drawbacks but the OD was needed so I could use it long distance. Started out with a TH400 and 2.48 first, but a $200 700r4 in good condition was too good to pass up. They don't like to downshift from OD, but I tweaked it so it will at full throttle.
Anyway, thanks guys for the info! Pulling the truck apart here to paint in the next month or two, so doing some upgrades while I have easy access.
My 68 SWB
Al Silveira Music
Old 01-28-2018, 04:44 PM   #8
garyd1961
A set of vortec heads would probably do more than a cam swap.
garyd1961 is offline   Reply With Quote
Old 01-29-2018, 05:52 PM   #9
DieselSJ
With the SBC that I had in my old CJ5, I used an Isky cam with a 208/216 duration at .050. It had awesome torque.
https://www.summitracing.com/parts/i...7012/overview/
Powerband is wrong in the description - it was done before 5000rpm.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 01-30-2018, 11:39 AM   #10
Stryder67
Doesn't sound like you'd like to do anything with the exhaust, however don't underestimate what a set of long tube headers can do. Yeah they are a little noisy compared to the ram horns. As far as cam I'd have to vote for the 1102 cam with stock heads. Maybe look at some rockers as well
Stryder67 is offline   Reply With Quote
Old 02-01-2018, 05:03 PM   #11
Tom
driving is in my blood
Tom's Avatar
I've never found a 350 lacking torque. They are gutless HP wise stock but torque? They can tow more then the truck is rated for. Guess I've driven non trucks too much, now that's lacking torque.
Old 02-03-2018, 06:32 PM   #12
nikwho
nikwho's Avatar
+1
Also, replacing heads and cam would be a couple of good upgrades to make at the same time! But, that also snowballs into buying a new intake manifold, since the Gen 1 SBC intake won't work on the Vortec cylinder heads.
'68 GMC - BBC/TH400
Old 02-03-2018, 06:41 PM   #13
Richard2112
Richard2112's Avatar
I'm interested in doing a similar set up. Let us know what you decide/how it works out.
Richard2112 is offline   Reply With Quote
Old 02-04-2018, 12:12 AM   #14
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I did a rebuild on a stock 72 350 four years ago for my 72 C/10 and was looking for a cam for towing an occasional 7000LB tandem trailer. I went with the Lunati Voodoo 256/262 cam/lifter kit, http://www.lunatipower.com/Product.aspx?id=2323&gid=287 and I couldn't be happier! Still pulling like a train! I added an Edelbrock 2101 with the factory 4MV Quadrajet and Hedman long tubes. Bone stock heads and pistons with MSD HEI...PS. 14.9 aint bad!
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 02-12-2018, 11:34 AM   #15
69SCSS
69SCSS's Avatar
I have 2.5" duals with the ramhorns, and used to have headers. As much as I liked the sound of them, they leaked all the time. The ramhorns are mellower sounding, but seems to not have restricted it too much. Of course with a bigger cam, that may not be the case.
Thanks for the suggestion, that's right in the ballpark. I'll be rolling the truck into the garage for disassembly next week (hopefully) and will let you guys know what I wind up with.
My 68 SWB
Al Silveira Music
Old 02-12-2018, 02:12 PM   #16
Keystone_Hate
Check out Engine Masters on YouTube. They do a lot of comparisons on small block chevys.
Cam comparisons.
Headers vs. Manifolds.
Intake manifolds.
Roller vs flat tappets
EFI vs Carb
All kinds of cool stuff and they dyno all of it.
just something to check out.
Keystone_Hate is offline   Reply With Quote
Old 10-18-2018, 07:01 PM   #17
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Updates?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-19-2018, 12:35 AM   #18
Greasey Harley
Greasey Harley's Avatar
I just built this motor.
I used 72cc swirl port TBI heads. They make good low end torque and do nothing over 4500rpm
Mtc1 cam :high lift short duration good low end torque
Flat top pistons 9.25:1 compression
Cast iron manifolds, 2.5" dual exhaust with an H pipe
Hei and a Q-jet
That is a low end torque combo. ...at least I hope so. It's still setting on the engine stand.
Greasey Harley is offline   Reply With Quote
Old 10-19-2018, 12:30 PM   #19
LostMy65
LostMy65's Avatar
Hei and a Q-jet
Good info.
I have 2.5 rams horn exhaust manifolds and don't want headers.
I very rarely drive over 55, and 90% of the time 45 mph max. And I drive a maximum of 6000 miles a year.
The gm goodwrench I have is very low miles, so I'm wanting to do low cost upgrades to make it as best suited as possible for daily driving.
Old 10-22-2018, 08:07 PM   #20
AcampoDave
AcampoDave's Avatar
Cam comparisons.
Intake manifolds.
EFI vs Carb
Yeah, what a great series. I learned about it from this site.
AcampoDave is offline   Reply With Quote
