Old 03-27-2024, 07:42 PM   #1
toppdawg46
69 GMC Door Handle assembly
Just wrapping up the resto-mod on my 1969 GMC pickup, looking to install a Retro-fit Power Door Locking Kit with Remote Start sensor. I plan on keeping/using the original door handles...Any recommendations? Best sources, etc. If anybody's tried this I would appreciate any advice about significant issues I might run into....successful or not...Thanks much!
toppdawg46 is offline   Reply With Quote
Old 03-28-2024, 08:06 AM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: 69 GMC Door Handle assembly
NOS GM is best quality, but due to age, some are shelf worn, and need rechroming for high end builds.
Look for part numbers 3927899 and 3927895
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 03-28-2024, 09:41 AM   #3
Good luck finding N.O.S. door handles. You will find many claimed to be N.O.S. that are GM Restoration Parts, not Genuine GM. The bar code on the box is the dead give away. Those are reproduction parts, same as other companies, that only GM has legal right to put their part number on and use GM packaging. The same parts can be had at normal pricing from the reproduction parts source of your choice
Old 03-28-2024, 11:07 AM   #4
1970cstblazer
RH as offered by a board vendor:
https://67-72chevytrucks.com/vboard/...d.php?t=823793
LH on Ebay:
https://www.ebay.com/itm/20462518650...Cclp%3A2351460
Old 03-28-2024, 11:49 AM   #5
toppdawg46
Thanks for the speedy replies...Just ordered Kit from A-1 Electric...2 Door Power Door Lock & AVI-2101 Keyless Entry. Hope I did right...You guys came through...again! Thanks
