11-30-2020, 06:14 PM | #1 |
How to replace driveshaft in trans?
Getting ready to pull my engine (350) and trans (TH350) out for cleaning, resealing, etc. From what I've read here, the driveshaft will pull out of the trans as I remove the engine/trans. Sounds easy enough. When I reinstall the engine and trans, what's the best way to re-insert the driveshaft into the trans? This is my first time doing this and didn't find info on it. Thanks!
72 C10 lwb fleetside -stock 350/350 combo |
11-30-2020, 06:38 PM | #2 |
Re: How to replace driveshaft in trans?
Unbolt the drive shaft first
Not knowing your truck its either 1 or two peice setup remove it drain tranny before removal Engine hoist I use most i separate engine from tranny |
11-30-2020, 06:48 PM | #3 | |
Little to no transmission fluid will escape when you remove the driveshaft (the fluid level is below the height of the tail shaft). But, if you tilt the transmission down at the rear, fluid will pour out. So, drain the fluid before removing the trans/engine assembly. And, tie a sturdy bag around the trans tail shaft to catch the residual oil that will want to escape even after draining the trans fluid. Last edited by Davidf; 12-01-2020 at 11:05 AM. |
11-30-2020, 07:19 PM | #4 |
Knew I forgot something lol. It's a 2-piece.
11-30-2020, 07:22 PM | #5 | |
11-30-2020, 08:06 PM | #6 |
Old member
They make a plastic piece to go in the end of the transmission to hold the fluid in. You can buy them cheap and tape it to the transmission while it's being pulled. Good idea to have a bag also though.
When going back in have the drive shaft pulled off the rear end and center bearing. Once you have the motor & transmission sitting back in the truck just slip the shaft back in it and install it back to the rear end and center bearing. https://www.summitracing.com/parts/p...caAmqSEALw_wcB
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
11-30-2020, 08:17 PM | #7 |
You can’t beat the experience on this site.
71 C-20 07 Magnum RT AWD |
12-01-2020, 12:08 AM | #8 |
Thanks gents, I appreciate it. I'll let you know how it goes once I get to it lol. Should be soon
12-01-2020, 08:56 AM | #9 |
That plug will come in handy if your not planning on draining the transmission.
