10-23-2008, 05:21 PM | #1 |
born to lose
Hacked dash fix
When I was young and stupid(er) (I'm still a numbskull) I let my buddy hack my dash to put a cd player in(he did a terrible job). The radio and speakers got stolen about 2 years ago, so I have been looking at a big ulgy lop side hole where a cd player use to be and its bugging really bad. I don't know if im going to put a cd player back in there or what. I was thinking of putting my gauges in there but again im not sure. I'm curious if anyone has ever fixed one of these and what they did. I guess the only fix would be to cut in new metal in it but im not sure. Heres a picture of the ugly bugger.
_____________________ '67 Chevy Belair Wagon 283 Powerglide '68 Chevy II Nova 2 door 350 TH400 Sold!! '71 Chevy C20 350 TH350 '71 Chevy C10 Burb 350 TH350 stolen totalled gone.... Burb Build http://67-72chevytrucks.com/vboard/s...d.php?t=475155 Nova Build http://67-72chevytrucks.com/vboard/s...d.php?t=498979 Wagon Build http://67-72chevytrucks.com/vboard/s...d.php?t=543052 Not giving a truck. |
10-23-2008, 05:39 PM | #2 |
Old Skool Club
Re: Hacked dash fix
Mahanian has a possible fix for you. It still takes a DIN unit, but the billet piece he sells will let you have a clean looking dash and that will hide the butchery that you are not in love with. Check him out. He's on the board and there should be a thread about his billet radio panels.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
10-23-2008, 05:44 PM | #3 |
sharp as a marble
Re: Hacked dash fix
Mahanian has the plan !!
10-23-2008, 06:40 PM | #4 |
Re: Hacked dash fix
Slick even though I still have the stock non working am radio I've been planning on putting a new sound unit in the dash.
10-23-2008, 09:13 PM | #5 |
Re: Hacked dash fix
A radio delete is 8"x2 5/8" so if it covers your hole, you can go that route. The clips that hold it on use the round holes so if they are gone, another method is needed to hold it on...
10-23-2008, 09:20 PM | #6 |
Still livin the "dream" in '54
Re: Hacked dash fix
Wow, looks like the guy who worked on your dash worked on mine at some point too... I posted before and after pics...
I made a new plate from thick sheet metal (like 18 gauge) and used 3M double sided tape to hold it to my dash so I wouldn't have to use screws... has worked perfect... Don
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo Last edited by Richard8971; 10-23-2008 at 09:27 PM. |
10-23-2008, 09:33 PM | #7 |
Tot Roddin'
Re: Hacked dash fix
If you want to go back to stock, you can always purchase a repair panel from someone and weld it in and repaint it.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-23-2008, 11:27 PM | #8 |
Re: Hacked dash fix
I've been thinking of finding the diameter of the knob holes and making a couple mini patch panels, since it looks pretty easy. A little of the hole area is left and a little of the corner in the square area is still there, so the size can still be determined.
I just need a volunteer to measure the diameter of the holes (obvious hint). The other ideas are bend up some clips that will work similar to the stock ones, or epoxy two bolts to the back of the delete plate and just use some strips of sheet metal about 1x3 to clamp the plate in place. Last edited by 72lb4x4; 10-23-2008 at 11:29 PM. |
10-25-2008, 12:23 AM | #9 |
born to lose
Re: Hacked dash fix
Thanks for all the replys. I think I will order that billet cover from Mahanian when I get paid.
