08-10-2015, 03:07 PM | #26 | |
Re: Transmission has me pulling my hair out !!!
No I didn't drop the pan. The trans was a running trans. I know the car. We pulled the motor and did an LS swap. I pulled the trans loose. The only fluid I lost was the fluid in the lines. Took it home , put it in my truck. Never took out the converter , never lost any fluid other than what came out of the lines and what was in the cooler.The trans should have been pretty close to full I would have thought it anyway. I'm going to put some more fluid in it and see what happens. And thanks to ALL of you guys for the suggestions. I'll let ya know what happens. |
08-10-2015, 06:04 PM | #27 |
well a good sign is you have 1st&reverse so at least it can move if needed
do like everyone suggested and keep adding fluid.at this point you'll only be out the cost of the juice. one question did the trans mount easy? its real easy too muff up the pump in the front of the trans if you dont get that t c too seat correctly....just sayin, but usually you wouldnt have any gear at all. i'm not a fan of auto's at all my left foot falls asleep too easy
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
08-10-2015, 07:01 PM | #28 |
people in the know realize when a tranny is moved without the driveshaft yoke in place it pukes fluid all over the floor
guess you must of missed that huh?
08-10-2015, 07:40 PM | #29 |
>>The trans was a running trans.<<
>> it didn't show any fluid on the stick. I put a quart in it because I figured it needed at least that << >>I put another quart in and checked it . It was to the add a Pt mark. I put a pint in and ...<< >>I put another quart in and ...<< >>Lol... I've put 5 quarts in it already. << >>I'm going to put some more fluid in it and see what happens. << Are you saying that each time you have put fluid in it, it came up to the full mark?
'67 GMC 2500, 292, 4spd, AC |
08-10-2015, 08:07 PM | #30 |
What dipstick and tube are you using, the one for the truck or the vette? One may have a deeper pan than the other.
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 Sierra Grande LWB, 350/TH350, Factory Air Lots, of future mods planned!! |
08-10-2015, 09:05 PM | #31 |
blood type; Retumbo
no one here has heard of a manual valve body?!
Drive it around the block starting with shifter in 1st. Get up to about 20, shift to 2nd. Shift into 3rd at 40 or so. talk to the guy you got it from. Ask him if it's got a manual valve body http://www.forabodiesonly.com/mopar/...ad.php?t=82680 http://www.chevelles.com/forums/arch...p/t-70640.html http://www.summitracing.com/search/p...l-valve-bodies There's plenty more reading out there but these should get you "in the know"
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
09-07-2015, 09:41 PM | #32 |
pulled it , rebuilt it . Running Fine now, .
