Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 10-16-2019, 11:13 PM   #1
cwcarpenter98
cwcarpenter98's Avatar
WTB: Overdrive Cable Clamp
I'm looking for the overdrive cable clamp that secures the cable at the solenoid.
I've included a pic of what I need and my current setup.
I could probably end up making one, but while I'm at school and don't have access to the stuff I need to make one, I figure I'll see if there's one out there somewhere
Christian Carpenter
1963 C10 - Frankentruck 283, 3 speed with overdrive
Overdrive wiring here
1981 C10 - Penny 305, th350
1995 Dodge Dakota Sport
Old 10-16-2019, 11:50 PM   #2
shortstep60
Re: WTB: Overdrive Cable Clamp
I have a over drive trans in a 65 will look and see if it has a clamp
shortstep60 is offline   Reply With Quote
Old 10-17-2019, 01:39 PM   #3
cwcarpenter98
Thanks!
Christian Carpenter
Old 10-17-2019, 04:10 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
Will this work?
http://www.billstruckshop.com/60-66.html
Old 10-17-2019, 07:39 PM   #5
cwcarpenter98
Thank you for the suggestion Rocknrod. I just went out to look at the size, and unfortunately the clamp is much bigger than the OD cable
Christian Carpenter
Old 10-21-2019, 12:01 PM   #6
cwcarpenter98
Still looking
Christian Carpenter
Old 10-21-2019, 05:05 PM   #7
shortstep60
Mine is gone sorry I could not help you
Old 10-21-2019, 07:35 PM   #8
cwcarpenter98
Thanks for looking, I appreciate it
Christian Carpenter
Old 10-28-2019, 01:09 PM   #9
GMCNUT
GMCNUT's Avatar
Just make your cable larger by adding some fuel line over it nice and snug, then stick that into the park brake cable clamp and tighten. a few rounds of Black Gorilla tape on the OD cable would also work
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 10-28-2019, 01:26 PM   #10
cwcarpenter98
That is a good idea. I'll have to see if I can make it work next time I go back home. I don't have all my spare parts and such down here at college
Christian Carpenter
Old 01-10-2020, 02:48 PM   #11
cwcarpenter98
Still looking for the clamp
Christian Carpenter
Old 03-08-2020, 05:02 PM   #12
cwcarpenter98
Maybe someone has one that I could get some measurements off of so that I could make my own??
Christian Carpenter
Old 03-08-2020, 06:54 PM   #13
shortstep60
I have one on a four bolt over drive that I am going to sale. I will make one for you. Thanks for help me on my overdrive.
Old 03-08-2020, 08:54 PM   #14
cwcarpenter98
Thanks! I'm glad I could help ya with it. It was good talking to ya again as well
Christian Carpenter
