Old 02-28-2014, 04:42 PM   #1
The German
The German's Avatar
Brake Hose lenght...C10 4,5" drop
Hi guys!
Ive lowered my truck 4,5" at the front.
Now my brake hoses are to long!
Which is the right lenght of brake hoses that ive to buy?
Can someone give me a link which ive to order? I just look at summit,but there no specified lengths!?
Regards from germany
Sascha
The German is offline   Reply With Quote
Old 02-28-2014, 09:21 PM   #2
seamus2154
Re: Brake Hose lenght...C10 4,5" drop
Too long?? I just lowered mine 5" and mine are too short and tight. I used 3" drop springs and a 2" drop spindle so maybe the way I dropped it changed my length different from yours.
seamus2154 is offline   Reply With Quote
Old 02-28-2014, 09:36 PM   #3
leddzepp
Moderator
leddzepp's Avatar
X2. I don't like how short mine are either and was actually wondering if there are any longer ones that bolt in. I don't see how his can be too long either
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-28-2014, 09:43 PM   #4
hfd410
hfd410's Avatar
X3 here, 4/6 drop and used stock hoses.
My 71 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=548438
hfd410 is offline   Reply With Quote
Old 02-28-2014, 10:21 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Been there and learned the trick. Buy 3/4-1 ton hoses for 71-72 trucks. They are about an inch longer than half ton hoses but otherwise identical in every way. Most 67-72 specialty vendors sell them. I buy mine from Kenny's Trucks. I use them on all my lowered 71-72 trucks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-28-2014, 10:29 PM   #6
seamus2154
I learned the hard way that the right and left fronts brake fittings to the hose are different size internal threads on my 72. Is this different size left and right the same on the 3/4 ton truck???? Thanks for your experience because I need longer hoses. Will this one inch be enough seems pretty tight now.??
Old 02-28-2014, 10:33 PM   #7
Tx Firefighter
I've built the same truck a bunch of times basically. All my piles get drop spindles and springs for a total of 4.5 drop in the front. On the 71-72 trucks, that drop causes the brake hoses to be taught. About 15 years ago I mentioned this to Kenny at a swap meet and he showed me the 1 ton hoses. Exact same in all manners as the half ton hoses, except an inch longer. That extra inch gives enough slack to take the hoses out of a bind. Since then every 71-72 front end I've used under a truck, I buy the 1 ton hoses. Problem solved.
Old 03-01-2014, 01:03 AM   #8
Rod Run
Rod Run's Avatar
That is one cool bit of info right there
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 03-01-2014, 07:31 AM   #9
The German
The German's Avatar
Heres a BIG picture....!!!
On the right side you can see that the house scratch at the lower arms!
That is my problem!
Old 03-01-2014, 09:12 PM   #10
seamus2154
Thanks Brother! I like the way the stock hose has the notch at the caliper and the keyway at the frame so 3/4 ton it is!! I have CPP 2" drop spindles and 3" springs hope that 1/2" difference still gets me the needed length I need?/ Thanks
Old 11-02-2023, 01:27 AM   #11
T49ers68
T49ers68's Avatar
I found for my 1968 C10 the Corvette hose is an inch longer. Makes perfect for lowered 1968s.
T49ers68 is offline   Reply With Quote
