Old 10-17-2018, 08:36 PM   #1
72Blazerod
72Blazerod's Avatar
Power Lock "Reset" 1981-1987 Suburban?
Okay, I was trying to fix my power windows. I had the power door lock switch out and bare. The power locks did work until the contacts touched my door handle and sparked (a very small spark, like a static electricity spark). I assumed they shorted out. They haven't worked since. Is there any way I can "reset" the power door locks switch? Any help is appreciated. Thanks
1987 GMC Suburban 1/2 ton 4x4 (Beater)
1998 GMC Suburban 2500 4x4
1972 Olds 442 Convertible
2006 GMC 2500 Duramax Crew Cab (Sold)
1972 Blazer 4x4 (Sold)
72Blazerod is offline   Reply With Quote
Old 10-18-2018, 08:55 AM   #2
blindbug
Re: Power Lock "Reset" 1981-1987 Suburban?
Have you checked your fuses? Usually a spark like that will cause a fuse to pop for the power lock circuit. I don't know what year you have, but find a fuse diagram, pull the power lock fuse (I think it's usually labelled ACC, but I don't have power locks, so I'm not sure)... and replace the fuse with a new one, or a same-amp from a different circuit. If it works, replace the fuse and you're back in business. If swapping from a different circuit doesn't work, you can also bridge the gap with a short piece of wire to make sure that the fuse you used isn't blown as well (TEMPORARILY, make sure you use a correct fuse!).
blindbug is offline   Reply With Quote
Old 10-20-2018, 01:47 AM   #3
72Blazerod
72Blazerod's Avatar
Anybody know which fuse is for power locks in a 1987 GMC Suburban? What's it labelled?
