01-08-2018, 06:29 PM | #151 |
Re: Yet another 72 going under the torch, factory 3 speed on the tree!
Yea I think I saw those, I was wondering if these were any better
Joe 1968 K20 1970 K20 Semper Fi |
01-08-2018, 08:44 PM | #152 |
Active Member
Do you have a set of the front hold down brackets?
01-08-2018, 11:02 PM | #153 |
01-08-2018, 11:03 PM | #154 |
01-08-2018, 11:08 PM | #155 | |
01-08-2018, 11:12 PM | #156 |
Active Member
Sorry about that. Yes, for the top.
01-08-2018, 11:14 PM | #157 | |
01-08-2018, 11:17 PM | #158 |
I had already purchased the rear seat brace from you several months ago and I realized that I need these front two mount which I believe that they are the same as the inside spare tire mounts too. Thanks 1rippin6.
01-08-2018, 11:19 PM | #159 |
I had already purchased the rear seat brace from you several months ago and I realized that I need these front two mount which I believe that they are the same as the inside spare tire mounts too. Thanks 1rippen6.
01-08-2018, 11:31 PM | #160 |
01-08-2018, 11:39 PM | #161 | |
01-09-2018, 06:16 PM | #162 |
Active Member
01-09-2018, 11:21 PM | #163 |
01-09-2018, 11:22 PM | #164 |
I got home after dark will take a look tomorrow.
01-09-2018, 11:27 PM | #165 |
Active Member
01-09-2018, 11:52 PM | #166 |
01-09-2018, 11:56 PM | #167 |
Did you ever get a chance to check on those hatch latches?
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
01-10-2018, 12:00 AM | #168 |
01-10-2018, 09:50 AM | #169 |
Received parts yesterday. Thanks again.
01-10-2018, 10:48 AM | #170 |
01-10-2018, 07:39 PM | #171 |
Sorry didn't get home until after dark again, its suppose to be 50 degrees Friday so I will get you an answer by this weekend.
01-10-2018, 08:17 PM | #172 |
01-10-2018, 09:58 PM | #173 |
Pulled the latches 1 is ok the other needs the spring replaced which I can do. I grind the crimped end off replace the spring and then I weld the pin in. Works good as new and the weld can be ground off if it would need worked on again. Let me know if still interested and I can get it repaired this weekend.
01-10-2018, 10:26 PM | #174 |
How much would that be?
01-11-2018, 08:32 AM | #175 |
