05-17-2023, 11:49 AM | #26 |
Re: 71 350 Rebuild advice needed - Head and Cam Suggestions
OP you might just want to put the 4 brl on now and see what its like. It should certainly wake it up but IIRC the heads were different on 2 brl vs 4 brl cars also so published 4 brl HP would be less with the smaller heads
With that said when I put a 4 brl on my 327 210 hp 2 brl motor it really woke it up. If you do go cam, lifters, new heads at that point you would want to hone, re-bearing and ring the motor. That total cost is likely as much if not more than a new crate motor with modern heads, 1 piece RMS and full hydraulic roller cam....and a warranty. I found this to be the case when I needed to rebuild my 327. Check out Blueprint Engines. What I got. The 411hp/413tq REALLY makes a difference over mid 200hp motor. |
05-17-2023, 11:53 AM | #27 |
Larger valves in the heads doesn't automatically equate to better just like a larger cam doesn't automatically equal better performance.
The right cam & heads (or re-worked heads) w/the right pistons (compression) are what will make power. A plain-jane early 70's 350 would likely have 17-18cc dished pistons. Couple that w/the 76cc chamber heads & you have your basic low compression no frills sbc. Larger valves won't help compression nor will they help increase power much when there's minimal pressure supplying the mix. A larger cam w/more aggressive timing events would help things sound better (like it has power) but not boost perf by much if any. Too big of a cam w/low compression can actually hurt things when below the upper rpm range as low speed cylinder pressure is in the basement. You want/need flat-top pistons & smaller chamber heads. Later model Vortecs offer superior flow + velocity vs any previous cast iron head & their smaller 64cc chambers help compression. You can spend money on the old 76cc heads but won't get the same results as you could swapping to better flowing heads. It's all about the combo of parts. We did several 350ci motors years/years ago (pre-Vortec era) w/flat-top pistons & iron 76cc GM 882 heads (milled for true flat surface & to help compression). Each had a mild cam (~222° int duration was the largest cam) & made just over 300hp on the dyno (so 240-ish HP to the ground). All worked well but I don't see you hitting a 300hp number w/o pistons & spending $$ on the heads. There are aftermarket alum heads that now offer much more bang for the buck & don't require the Vortec specific intake & related parts (which adds to their overall cost to use). I recently picked-up a 69 350 that was plucked out of a fellow board members C10. It will get the same treatment & be the replacement for my '78 Malibu's low compression 305sbc. The dished pistons will be swapped out for flat-tops; some aftermarket/better flowing alum 64cc heads will replace the small valve iron units, & a mild hyd roller cam (basically the GEN2 sbc GM LT4 Hot-Cam) to upgrade the timing events. I'm estimating 300hp to the ground.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-17-2023 at 04:00 PM. |
05-17-2023, 03:33 PM | #28 |
Scoti your last post explained more about building a SBC than anything I have ever read ! Thanks
71 C-20 07 Magnum RT AWD |
05-17-2023, 05:00 PM | #29 | |
Constantly reading everything I can on the subject & doing things the wrong way will teach you a thing or two. Case in point... 2 1974 Z/28's. Both had 350sbc's; 4spd Muncies; full length headers/true 2.5" dual exhaust; & 8.5" 10-bolt rear ends. Z/28 No.1 * Dished pistons swapped to flat-tops * Old school 462/Fuelie/Cammel-Hump heads w/2.02INT valves; w/porting + milled for straightness & compression bump * CompCams 230/280/.480" lift hydraulic flat tappet cam * Victor Jr & 750 mech secondary Holley * 27.4" rear tire & 4.11's Z/28 No.2 * OE dished pistons * 70's era 993 76cc iron heads w/2.02INT valves machined/added * CompCams 244/292/.501" lift hydraulic flat tappet cam * Victor Jr & 750 mech secondary Holley * 26.5" rear tire & 3.08's Z/28 #1 would snap your neck back & pin you to the seat accelerating. Z/28 #2 was a dog off the line & generally had no power but sounded like it had more balls vs #1. It did not..... The #2 car was mine. The motor was already built/car was set-up when I bought it. Car #1 was a buddys build. I was hoping mine would be as stout or more w/fresh tune-up stuff but you can't overcome that cylinder pressure difference & the heads ability to move air. Mine got totaled before I could re-work the motor. The drivetrain was plucked & certain parts were re-used. The rebuilt motor was the 1st of the several mentioned in my previous post. The much milder combo w/compression had 100% more seat of the pants power.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-17-2023 at 05:09 PM. |
05-17-2023, 06:07 PM | #30 |
It is very difficulty to rework head for the price of new these days. The power of mass production is just difficult to make up. Especially true with pre-70/s heads without hardened seats. Even the early valve stems were soft and are likely badly worn if run on no lead fuel.
Newer heads have; Better flow, Stellite valve stems, larger valves, hardened seats, better swirl and higher compression. Personally I can see no reason to go back to the 70's technology unless you are restoring a truck. |
05-17-2023, 06:26 PM | #31 |
05-17-2023, 06:36 PM | #32 | |
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
05-17-2023, 06:54 PM | #33 |
Absolutely a contributing factor.
But that 10:1 vs 8:1 & the flow of those 462's vs smog version 76cc heads was worth more from my perspective. That rebuilt/updated 350 went into a g-body elcamino w/less gearing (26" tall tires/2.73's). It had more guts off the line & enough low-end to twist the d-shaft in half like a twisting a coke-can.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-18-2023 at 08:49 AM. |
05-17-2023, 06:59 PM | #34 |
I was told mine had flat-tops but learned it wasn't so. How was the piston type verified on your engine?
05-17-2023, 07:36 PM | #35 |
05-17-2023, 08:34 PM | #36 |
Gotcha. Wasn't sure how far apart you had inspected things.
05-17-2023, 10:11 PM | #37 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
05-17-2023, 11:45 PM | #38 |
Yeah I pulled the heads before we loaded it up and since I've brought it home, I've pulled all the rods and crank bearings. Wanted to have a good idea of where I'm at before I decide what or how to build it.
Since it's a flat top pistons, what would you recommend for a head and cam? From my research, the 76cc heads with flat pistons should bring me to 9.0-1 compression which is pretty much where I'd like to stay since I want to run it on regular gas. Maybe mid grade 89 octane at the most.
05-17-2023, 11:46 PM | #39 |
Those are nice HP and Torque numbers Greg! I'm jealous!
05-18-2023, 08:05 AM | #40 | |
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
05-18-2023, 08:14 AM | #41 |
15 years ago, I built a 327. I know it wasn't a 350 but for what it's worth, this was the set up. Absolutely the best pulling little engine I ever had.
327 large journal crank Flat top pistons 1970 pickup truck heads with 2.02s (enlarged valves but open chamber) New valve springs Edelbrock performer and 750 carb Headers Crane cam (card pictured) Your results may vary, but I had it in front of a muncie m20 Good off throttle reponse, decent idle, hard pulling little engine. I sold the car to a friend in 2011 and it still runs great.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1971 c10 swb/1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71 |
05-18-2023, 08:37 AM | #42 | |
68 C10 Longbed
05-18-2023, 09:28 AM | #43 | |
05-18-2023, 11:25 AM | #44 |
The head casting #'s are 3986336 = 76CC 1.94/1.50 Valves
05-18-2023, 11:29 AM | #45 |
Wow, that's a gorgeous car!! Lifes not fair
05-18-2023, 11:30 AM | #46 | |
05-18-2023, 12:50 PM | #47 | |
FYI-But same foundation is only if you squint really hard. Might both have an 010 casting 350 block but that is where the similarities start to fade. A 1972 LT1 is 9:1 compression (in '70 it was 11:1), 4 bolt mains, steel crank shaft, solid lifter engine. A 1972 Biscane 350 is 8.5:1 compression, 2 -bolt mains, Cast crank, hydraulic lifter engine. All those things interchange for the most part, but are much more heavy duty and/or performance oriented for the LT1. LT1 also had a bigger oil pan, windage tray, different timing chain, better connecting rods, and so forth than the low HP 350s that year.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 05-18-2023 at 02:50 PM. |
05-18-2023, 12:53 PM | #48 |
I suggest you call the cam manufacturer for recommendations, like Comp Cams. Tell them what you got and what your expectations are. With your current motor and stock rebuilt heads I would probably stick with something like the Comp Cam XE250H or XE256H cam.
Here`s some of their dyno charts: https://www.compcams.com/dyno-graphs Just my .02 |
05-18-2023, 01:35 PM | #49 | |
05-18-2023, 01:48 PM | #50 | |
68 C10 Longbed
Here are the head specs for 71 & 72 Z28: 3973487 comes up as s good for '71 or '72 Z/28 head at 2.02/1,6 valves and a 75.47 cc chamber. Last edited by ghackett1; 05-18-2023 at 02:08 PM. |
