Old 06-02-2016, 07:39 PM   #1
GR8-68
GR8-68's Avatar
Spring perches ?
Okay, so I am going to be using a cpp rear shock mount crossmember the question is when I removed the oem crossmember it also removed what I would refer to as the upper spring perches, which I have added a picture of. Do I have to have these on there ? Or can I bolt my springs directly to the frame ? All the pictures cpp shows have the cnotch kit installed which seems to replace this piece. I dont see any issue bolting them to the frame other than it may cause abnormal wear. Thanks for any help
GR8-68 is offline   Reply With Quote
