08-23-2019, 12:38 PM | #1 |
Re: 292 Power Steering setup
Just got a complete running ps pump with brackets and the water pump pulley this morning. Came from a 75 3/4 ton Chevy. Text for more pictures at 309-343-9127. I can also post them here. I think $300 plus shipping would be a reasonable price. Located in IL. Thanks. Jeff
08-23-2019, 08:42 PM | #2 |
Donn you might check your t-stat housing to see if is like the one pictured above. If you still have pictures I sent you of my 292 power steering the lower hose coming out of my t-stat is as large as the bottom one so if yours is like mine I'm not sure if this will work.
08-24-2019, 12:06 AM | #3 |
If it’s an issue, I can get the Tstat housing as well.
08-24-2019, 08:40 AM | #4 |
I surely appreciate posting pictures of this PS. I have this mounting bracket and it will not fit my setup. Just changing the housing will not work either, it would also require a different water pump and I'm not sure what else. I'm afraid I will have to pass on this setup. Sorry I can't use it, but thanks for the effort in showing it to me.
08-24-2019, 09:47 AM | #5 |
No problem! You’d think GM would standardize these like they did so many other things. I’ll just throw this up on Ebay. Someone needs it lol.
