06-30-2012, 10:51 AM | #1 |
Re: off it goes
Thanks guys....
Posted via Mobile Device |
06-30-2012, 04:02 PM | #2 |
Re: off it goes
Tubs welded to the floor & bolted to the bedsides or will it get fully welded?
06-30-2012, 04:30 PM | #3 |
Re: off it goes
Tubs are going to bolt in....button head bolts from inside the tub to welded nuts in the box floor flange and then the same all around the top of the wheel tubs. If you look at the previous pic at the top of the page you can see the threaded holes for the tubs to bolt too.
