Old 05-20-2002, 02:10 PM   #1
69chevy97
Question front disc brakes
I have a 69 SWB 350 chevy with front drums. I want to change to disc brakes. I have been told that disc brakes from a 70-87 will fit is that true. Has anyone done this that could give me some info.
69chevy97 is offline   Reply With Quote
Old 05-20-2002, 02:19 PM   #2
Woody
Post
What you want is the whole cross member from a 71 or 72. But you can also use one from a 73-87 or so. Get the whole crossmember, front brake lines, master cyc, booster, bracket, peddle push rod, & prop. valve. Also get all the steering..tie rods, center link, idler arm, take it loose at the pitman arm. there are 2 holes (one each side) that you have to enlarge to get them to line up if it is a 73 or later. Then swap it out.
Woody
'69 Custom-10 Deluxe
Short Fleetside,Factory 350cid/TH400,A/C,PS,PB,Carpet
Coming soon 700R4, 350 Crate Engine, Pwr Disks...
Woody is offline   Reply With Quote
Old 05-20-2002, 04:04 PM   #3
Dean23
68cst_ss490
Dean23's Avatar
Post
I just did this swap on my 68. I used a crossmember and other needed parts from a 79. Worked well. You will need to oblong 2 holes as wellas drill 2. The swap goes really well. Fits like it was made to be in there
Dean
edmonton,canada
68 c10, project in works,350, th350, plain jane.
SLOW AND STEADY GETS THE PANELS READY
http://communities.msn.ca/MyChevytruckpage
Dean
edmonton,canada
a winter wonderland
2005 Chevrolet Avalanche LT
cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers.
http://www.cardomain.com/ride/3090973
Dean23 is offline   Reply With Quote
