11-18-2020, 11:54 PM | #1 |
Gas tank relocation ( fleetside )
Hello all
I have been viewing thread(s) on here for some time now Seen some great idea(s) but something still feels like its missing . . . Looking to relocate my tank to the rear but dont want it to not show past the rear bumper Also see some modifications at where the tank was installed almost by the back of the cab underneath and by the trailing arm support using a 65/ 66 mustang tank . Does any one have any insight or foto(s) of current or past mods that were done in relocating the tank ?
dont want to hear excuses, i want to hear solution(s) |
11-19-2020, 12:04 AM | #2 |
Re: Gas tank relocation ( fleetside )
I too wanted a rear tank that didn't show....so I started this thread http://67-72chevytrucks.com/vboard/s...d.php?t=621177 and I found it.
11-19-2020, 02:32 AM | #3 |
Noticed as well , interchanging jeep components is being used a bit on these older model c10(s) . . .
11-19-2020, 03:28 AM | #4 |
Here's nine. Early mustang tank I mounted between the frame rails
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
11-19-2020, 05:23 PM | #5 |
11-20-2020, 05:29 PM | #6 |
Any foto(s) of the plumbing ran ?
Like the idea tho ( using the reverse light housing as a filler )
11-21-2020, 10:22 AM | #7 |
Used the side fill. Had to run rubber vent tubing up & over the wheel well on both sides to be able to vent when filling at the gas station. |
11-25-2020, 07:23 PM | #8 |
Boyd Welding is what I used. Unless you on your knees you dont see it. I also got it black powder coated.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
11-25-2020, 07:42 PM | #9 |
Tanks Inc universal tank. Doesn't show below bumper. Two optional fill locations.
https://www.tanksinc.com/index.cfm/p...rod/prd121.htm |
11-26-2020, 04:42 PM | #10 |
64-66 CHEVY JUNKIE
Here's mine for Fuel Injection Engine.. It's a 1995 Roadmaster Tank, Hanger and Hardware.. 22 Gallons and Plastic will out last the truck.lol.
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E 2008 Silverado Crew Cab, 4.8 4l60-E 1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E 2017 GMC Serra 4x4 5.3 Vortec, 4l60-E Do It In A Chevrolet |
11-26-2020, 05:40 PM | #11 |
Bigmoe, 66shortbed, can you show how you plumbed your gas tank. Assume they are both side fill tanks?
12-01-2020, 11:15 AM | #12 |
Using a Rick's VaporWorx tank on my 66 fleetside. I did a bed fill for my swap.
12-01-2020, 11:36 AM | #13 | |
Moderator
12-01-2020, 11:49 AM | #14 |
The Tanks Inc. tank I referenced has two optional fill locations, one on top and one on the upper side. My truck is away in storage for the winter so I can't get pics but I have a picture I save of the guy who I copied with the exception that I used a metal elbow where it goes up through the floor. I had to make a hole in the frame to route the hose.
12-02-2020, 12:12 PM | #15 |
Found a picture of my tank installed. Tanks Inc. USPT-GH. (the vent was moved higher within the fender once the box was installed.)
12-02-2020, 01:41 PM | #16 |
Moderator
You ran the fill tube thru the frame?
12-02-2020, 03:36 PM | #17 |
