11-23-2014, 11:53 AM | #1 |
Tbi problem
I have à 89 chevy 305 5 speed at first it would not start checked for spark .have spark. Then pulled fuel line off to see if pump was working and nothing, pulled pump out and hose on pump was eating away. Changed that replaced fuel now the tbi is not working. Not letting fuel out What would cause that. Thanks for any help
11-23-2014, 08:47 PM | #2 |
Re: Tbi problem
Are you getting fuel to the throttle body?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
11-23-2014, 10:55 PM | #3 |
Re: Tbi problem
Yes getting fuel to it
11-23-2014, 11:17 PM | #4 |
Re: Tbi problem
With the key on there should always be power at the injectors. Check all the fuses. Make sure there is power to the injectors with the key on. The ECM grounds the other side of the injectors, to make the injectors open.
Did you check the ECM for trouble codes? If not, check for codes, and lets us know what you find, before you do the step listed next. A failed TPS (Throttle Position sensor), or ground wire to it, can put the system in the clear flood mode, making it so the injectors will not spray fuel. Try unplugging the TPS and see if the injectors spray fuel. The computer needs to receive a distributor reference pulse from the distributor module to trigger the injectors. It is possible for the module to produce spark without the computer getting a reference pulse. A bad distributor module or wiring between the module and the ECM/PCM can cause this. The ignition module in the distributor could be bad. Many of the bigger auto parts stores in my area will test the distributor module for free if you bring it in. Make sure when you install or reinstall the distributor module that you use heat sink compound under it. The compound helps dissipate heat from the module. Without it, the module will fail.
For those of you that are wondering why you are not getting replies to your thread: Did you give the model, year, engine, fuel system type, and transmission information? If it is modified from what came stock from the factory, let us know that too. |
11-24-2014, 08:26 PM | #5 |
Re: Tbi problem
Ok did thé code thing send map so changé it and works now
