09-20-2018, 09:07 PM | #1 |
What rear gear do I have?
Any of you guys or gals know what rear gear ratio I might have? The truck is a 1970 C10, half ton, originally inline 6 and powerglide. 12 bolt rear.
I have a 327 and 700r4 in it now. Trans has been in for a few years. The trans didn’t have a speedo gear on the shaft at install and I just got gears shipped in yesterday to get speedo going again. I put the gears in this afternoon and speedo is 9-10 mph slow according to gps. The truck has P235/75R15 tires that measure right at 28” tall. With the ratio calculator I used I figured for 4.10 gears and came up with 15 tooth drive gear and 43 tooth driven gear. SPID doesn’t give the ratio that I can tell. I just assumed gears were 4.10. Anyone know what gears were common for the inline and powerglide?
__________________ Jeff |
09-20-2018, 09:35 PM | #2 |
Re: What rear gear do I have?
1970 C10 w/6+PG was 3.73 standard, 4.11 optional - so if you have nothing called out on the SPID, the truck was born with a 3.73. No guarantee that's what's STILL in it, but as that how it came into the world.
09-20-2018, 09:48 PM | #3 | |
Appreciate that info. I’m pretty confident that the original ring and pinion is in the truck. I’ll most likely pull the cover this weekend and count the teeth to confirm before ordering more speedo gears. With the 700R4, converter locked up, it cruises along at 70 mph right around 2k rpm.
09-21-2018, 07:03 AM | #4 |
https://tiresize.com/comparison/
https://spicerparts.com/calculators/...rpm-calculator I see your tire size is closer to 28.9" In the transmission calculator I got: Ring & Pinion: 3.5 Tire Height: 28.9 Engine RPM: 2000 Transmission Gear Ratio: 0.696 Vehicle Speed: 70.62 If I change that to 3.73, I get 66.26, so you would be over 2K RPM at 70 mph. Played with it a bit, ~2100 RPM at 70 mph.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
09-21-2018, 08:09 AM | #5 | |
09-21-2018, 08:56 AM | #6 |
might be a difference in sidewall rigidity, or tire pressure. I think when the vehicle is in motion, the tires round out more as opposed to having a bit of a flat spot at the bottom.
looking at http://67-72chevytrucks.com/vboard/s...d.php?t=578793 and it look like the 3.36 ratio was available in 1970. I tried 3.36 rear with 28" tires. 70 mph would be about 1950 RPM.
09-21-2018, 10:11 AM | #7 |
Think I’ll just pull the cover off this weekend and count the teeth. Im sure the gear oil needs changing anyway.
09-21-2018, 11:07 AM | #8 | |
09-21-2018, 02:26 PM | #9 |
Learn something new everyday. Mine is 3.73 as well.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
