07-20-2020, 01:31 PM | #1 |
Added Sway Bar
My brother and I got my sway bar installed this weekend. Very happy with it. It’s certainly helped the darting and stability. Unfortunately it still has a bit of mind of its own. The only thing we haven’t tried is shimming the castor.
When I went to drive it again, for some reason my steering wheel was off center. Why would this be? We had to replace spring caps of course to accommodate. Drives fine, but do you think I need another alignment. It’s no big deal to straighten my wheel, just curious as to why it would be out of whack. Posted via Mobile Device |
07-20-2020, 03:43 PM | #2 |
Re: Added Sway Bar
Caster will help.
where'd you get parts for the swaybar? |
07-20-2020, 03:49 PM | #3 |
07-20-2020, 06:48 PM | #4 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: Added Sway Bar
Nice work!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
07-21-2020, 10:44 AM | #5 |
Re: Added Sway Bar
Those are nice brackets for sure!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-18-2020, 07:22 PM | #6 | |
Re: Added Sway Bar
11-18-2020, 08:24 PM | #7 | |
Re: Added Sway Bar
