Old 05-30-2015, 09:36 AM   #1
RogerKoop
RogerKoop's Avatar
A very nice restored A/T Tilt Column.
I have for sale a very nice restored A/T Tilt Column.
The rebuild includes a complete disassembly and inspection for worn or broken parts. This is followed by cleaning and bead blasting most parts. The Hub and Housing are powder coated on most of the time but not always. The rest of the column is then painted and rebuilt to factory specs. This includes packing and set torque to factory specs on upper bearing assembly. The lower bearing is cleaned and packed. The dust or air seal is replaced with a new one. I have the lower bearing retainer and the screws that mount to neutral safety / backup light switch re-cadmium plated. The original turn signal harness is checked using one of my trucks. It will be reused if it passes the use test. It is then cleaned and re-greased. A new turn signal harness is available on request. The column is rebuilt using new, NOS and quality used parts. Column is ready to bolt in.
On automatic columns the neutral safety/backup light switch is installed and has been adjusted to match the shift indicator. No additional adjustment should be needed, just plug and play.
If you want to replace the reproduction shifter arm I have a number of GM original shifter arms that have been re-chromed. All of them are high quality show chrome. I have both the standard pickup shifter as well as some out of vans which are about 4” shorter. Some owners opt for the shorter shifter based on a smaller steering wheel size. The price is an additional $50.00.
The following New or NOS parts were installed:
- Flasher Knob
- Lower Inner Dust Seal
- Upper Rubber Gasket to Dash Bezel
- Lower Rubber Gasket to Firewall
- Standard Shifter Arm or Short Van Shifter. Your choice.
- Shifter Arm Knob
- Tilt Release Arm
- Turn Signal Arm
- Tilt Pointer
- Transmission Indicator Lens
Price is $500.00 and up plus shipping to CONUS. I accept Checks, MO's and PayPal. Please include your shipping address. I will ship this via UPS or FedEx.
I have several more columns to complete, so if you would like one let me know.
Roger Koop
RogerKoop is offline   Reply With Quote
Old 05-30-2015, 09:37 AM   #2
RogerKoop
RogerKoop's Avatar
Re: A very nice restored A/T Tilt Column.
More pics
Roger Koop
Old 05-30-2015, 04:14 PM   #3
rkintn_68
rkintn_68's Avatar
They look good , great deal !!! Is the one posted 500.00 with either shifter
or are they all 500 + 50 for shifter ? How will you ship them in cardboard or
wood ? Can I get a quote to 37043 ? Thanks
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD
70 CHEVY C/10 LWB x 2 ----- SOLD
67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN "
Build thread :
http://67-72chevytrucks.com/vboard/s...15#post6826315
rkintn_68 is offline   Reply With Quote
Old 05-30-2015, 06:39 PM   #4
RogerKoop
RogerKoop's Avatar
PM sent
Roger Koop
Old 07-07-2015, 03:15 PM   #5
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 07-10-2015, 12:35 AM   #6
Woodnears
Quote to 67801 please
Woodnears is offline   Reply With Quote
Old 07-10-2015, 01:53 PM   #7
RogerKoop
RogerKoop's Avatar
PM sent
Roger Koop
Old 07-10-2015, 05:16 PM   #8
rharp
If someone brought you a column, how much would you charge to rebuild it for them?
1969 Chevy CST/10 396, PS, PB, A/C
rharp is offline   Reply With Quote
Old 07-10-2015, 08:04 PM   #9
Woodnears
Do you have any gear selectors that would work with my 4l60e? Beautiful column that's my only holdback. I would even take a tilt floor shift column if you had one restored.
Old 07-10-2015, 09:51 PM   #10
RogerKoop
RogerKoop's Avatar
Price runs around $250.00 to $300.00 plus what ever parts are needed.
Roger Koop
Old 07-10-2015, 09:55 PM   #11
RogerKoop
RogerKoop's Avatar
I should have gear selectors for a 5l60e, let me check.
I will have a 4-speed later next month. Still need some parts for it.
Roger Koop
Old 12-05-2015, 11:50 PM   #12
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 12-06-2015, 09:13 AM   #13
Ugly 61
Would you rebuild the tilt that I have in my truck or exchange it for one you have already rebuilt? If you would exchange is there any value in the one I have as a core?
Ugly 61
Ugly 61 is offline   Reply With Quote
Old 12-06-2015, 05:33 PM   #14
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
subscribed
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 12-06-2015, 06:04 PM   #15
RogerKoop
RogerKoop's Avatar
Ugly 61
I can do either. The price either way is based on what parts were used to rebuild yours and mine. What condition is yours and what parts will need to be replaced?
Roger Koop
Old 12-06-2015, 10:33 PM   #16
Ugly 61
Shift bowl is worn out where the gearshift pin goes through and the bottom 2 or 3 notches won't stay latched. Also need a new turn signal unit.
Gary
Old 12-13-2015, 01:25 PM   #17
RogerKoop
RogerKoop's Avatar
Gary
I've got the parts to repair yours. Its possible I may be able to repair your hub or replace it with a nice used one or NOS. As for it not staying latched I will need to get it apart to see whats happening. Let me know.
Roger Koop
Old 12-20-2015, 11:36 PM   #18
Ugly 61
I'll be starting on a complete rebuild on my truck after the 1st I'll contact you when I get the column out.
Gary
Old 12-21-2015, 10:13 AM   #19
RogerKoop
RogerKoop's Avatar
I have another tilt column ready for shipping.
Roger Koop
Old 01-31-2016, 01:17 PM   #20
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 02-02-2016, 09:38 AM   #21
RogerKoop
RogerKoop's Avatar
ttt
Roger Koop
Old 02-02-2016, 11:12 AM   #22
dfosh
I have a 68 gmc with a 700r4 zip 37745 short shifter price quote please .
dfosh is offline   Reply With Quote
Old 02-02-2016, 11:39 PM   #23
Cash3481
Loves all GMC trucks
Cash3481's Avatar
Roger,
I have 2 people asking for tilt columns...
Are you bringing any to the swap meet this weekend?
Mike
If your helping someone and expecting something in return... your doing business not kindness!
Cash3481 is offline   Reply With Quote
Old 02-03-2016, 09:33 AM   #24
RogerKoop
RogerKoop's Avatar
Originally Posted by Cash3481 View Post
Roger,
I can bring 2, one is $500.00 and the other is $540.00. Cash if you want to bypass the kansas sales tax.
Need any vent windows. I have 2 sets ready to go.
Roger Koop
Old 02-03-2016, 09:38 AM   #25
craneboy72
craneboy72's Avatar
what would a 4 speed tilt for a 71 blazer shipped to 01720?
craneboy72 is offline   Reply With Quote
