Old 10-23-2002, 01:32 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Question Aftermarket Volt Gauge wiring?
What is the proper way to run the power to an aftermarket voltage gauge so that it doesn't have constant power going to it when the key is off?.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-23-2002, 01:57 PM   #2
JimKshortstep4x4
Smile
You can use the terminal on your fuse panel marked ign. unfused
for the positive side and ground the other side. I would install a
small inline fuse on your positive wire, (3-5 amps).
Jim
Old 10-23-2002, 02:23 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Thanks Jim,
Sounds easy enough. I guess the fuse protects me from an electrical fire.
Jim
