05-02-2019, 04:33 PM | #1 |
Almost Satisfied
Sport Mirror Template
I purchased a set of doors off of a board member years ago. The holes for the mirrors were welded up. I want to put mirrors on my truck. Do any of you have a template that I can lay on my door to get the location for the holes correct? Sport mirrors on a 71-72.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
05-02-2019, 04:48 PM | #2 |
Re: Sport Mirror Template
Hopefully this helps
71 C-20 07 Magnum RT AWD |
05-02-2019, 04:52 PM | #3 |
I think I recall the mirrors are not mounted symmetrically. As in the two doors have different mirror locations.
Saskatoon, Saskatchewan Canada |
05-02-2019, 05:06 PM | #4 |
X2 on the mirror location on the passenger side, a little farther back, if this is not done,you will have the mirror in the middle of the vent window,when looking from the drivers side
01-05-2024, 08:31 PM | #5 |
yup I installed them symetrically and now I have issues with pass side. LOL
Cesar Diaz 1972 C10 Big Block 402 Cheyenne |
01-05-2024, 11:41 PM | #6 | |
The Older Generation
If it is because the mirror won't tilt in far enough to see out of it there is a thread on here somewhere that tells how to correct that by modifying the mirror a little bit.... LockDoc
05-02-2019, 05:39 PM | #7 |
Almost Satisfied
Learn something new every day! I didn't know that about the passenger mirror. Thanks for the drawing 54blackhornet!
05-02-2019, 06:51 PM | #8 |
Mabe look on the backside of the door to see whare the holes are.if that's possible.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
05-02-2019, 07:00 PM | #9 |
subd
05-02-2019, 07:33 PM | #10 |
subd
05-02-2019, 08:43 PM | #11 |
When you have the door panels off check at the bottom of the door inside. A lot of times the mirrors were removed and they just let the backing plates fall down inside the doors. Sometimes they are hard to see. LockDoc
05-03-2019, 09:12 AM | #12 |
Almost Satisfied
No backing plates and you can't get a good line of sight up in the door to see the original holes.
12-31-2023, 11:53 AM | #13 |
Active Member
I'm installing sport mirrors of my 70 C10 and the only difference is the vent windows have been removed and replaced with the one piece window from one piece products.
As per 54 blackhornet's, would it be necessary to move the passengers mirror back the additional 1.2"? I would presume since there is no vent window you would not need to do this. Any thoughts/suggestions here? Thanks |
12-31-2023, 12:28 PM | #14 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-31-2023, 12:54 PM | #15 |
My 71 GMC had about a dozen holes drilled into the doors for who knows how many sets of mirrors down through the years. Funny that both backing plates were still stuck in place behind the original holes. And yes the passenger sport mirror is useless.
01-06-2024, 04:05 AM | #16 |
Modifying the mirror or placement of the mirror?
Well if it's any contention Cesar, I installed mine per factory and it's still worthless. And yeah, it doesn't go far enough in.
01-06-2024, 04:49 AM | #17 |
My 72 originally came with D29 mirrors (painted tri-pods) In my younger years I installed oem sport mirrors per stock dimensions (right mirror further back) many years ago after purchase because they look cool. Agree, they kind of suck for viewing. Installed the DG4 mirrors in my rebuild. Shiny version of the tripod mirrors. My truck is a 4x4 so I think the mirrors look fine. Wish I never got rid of the original mirrors. Though I like the DG4's better.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
01-06-2024, 12:34 PM | #18 |
If anyone has info on modifying the passenger mirror to work I would be interested (maybe a link to the thread). I installed on the door per instructions, and still cannot pull the mirror in far enough to see. I am fairly sure it is an OE mirror.
01-06-2024, 06:27 PM | #19 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=181353 Starts with post #15. LockDoc
01-06-2024, 09:17 PM | #20 |
I've got OEM sport mirrors on my 71 K10 GMC. Mounted in factory locations
Have no trouble towing our holiday trailer. Not a large trailer |
01-06-2024, 10:37 PM | #21 | |
My C20 came with factory installed sport mirrors, but the passenger side mirror had been removed, and holes filled, then someone had used some aftermarket clamp on type mirrors for use in towing a camper. The sport mirrors I purchased were used, but in fairly decent condition, and I was trying to stay with OE mirrors due to this very issue. These were in good condition with the exception of the glass, which I had replaced by a local glass shop. Thanks for the link, and to resolve my issue I will likely modify the passenger mirror to allow it to swing in farther. I much prefer the look of the sport mirrors, and I have no intention on doing any towing, so I doubt I change them out. Last edited by chevmn; 01-06-2024 at 10:58 PM. |
01-06-2024, 11:29 PM | #22 |
The Niner
I had small mirrors on my 69 that were absolutely useless because they vibrated so bad, luckily the blind spot mirror was rubber isolated so I used to use that instead.
My 70 has below eyeline mirrors which I like the looks of and they work great.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
