Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 12-20-2014, 11:26 AM   #1
blazer2007
1980,s wiper motor upgrade ?
My wiper has always be slow at a idle and picks up at higher RPM.I was wondering if is a bad motor or is there upgrades like relays or what ever they do to upgrade the headlights and electric windows to get more power to the motors
blazer2007 is offline   Reply With Quote
Old 12-20-2014, 05:23 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 1980,s wiper motor upgrade ?
You have a voltage drop at the motor and or a poor ground. It would be really helpful if you stated what year truck and wiper motor and if it's a stock alternator,any wiring mods etc.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-21-2014, 11:31 AM   #3
blazer2007
It,s a 1980.s stock 350 auto
Old 12-23-2014, 01:55 PM   #4
gmachinz
A high current relay should help-but, before going that route, check your linkage for binding, make sure its greased/not binding. I've done the wiper motor relay mod on my trucks and gbodies to speed the motors up. This sidesteps the protection that the stock fuse provides though so you'd want to add a fuse before the relay to the wiper motor.
gmachinz is offline   Reply With Quote
Old 12-24-2014, 03:01 AM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Other than that he has a 1978 blazer with a 1980,s wiper motor. I don't know anything about the vehicle except it has a 350 engine.
I suspect he has a low amperage alternator perhaps a one-wire, or the wiring has been modified. It's also possible the ground on the wiper motor is not making good contact.
VetteVet
Old 01-12-2015, 11:05 AM   #6
C20ELEPHANT
C20ELEPHANT's Avatar
What aggravated me the most about rebuilt parts is sometimes small items are removed such as this ground strap. I bought mine before replacing it many years ago and noticed the rebuilt one did not have ground strap. So I drilled the rivet from the frame holding the ground strap and bolted it in place with the slotted screw, this may be your grounding issue as mentioned earlier by VetteVet. My truck does it to some degree, just figured wear and tear on the mechanical parts and degradation of the electrical system overall..
C20ELEPHANT is offline   Reply With Quote
