02-04-2017, 09:55 PM | #126 |
Re: 71 C10 6.0 LS ground up build
02-08-2017, 01:48 AM | #127 |
Getting the hood and fenders fit now. Will need to do a little work to get gaps right. Cowl panel needs some work too.
02-11-2017, 09:48 PM | #128 |
Started getting moldings mocked up and ready to drill all the holes. Any advice on hole size and approach for the clips would be great
02-14-2017, 04:49 PM | #129 |
Got all the holes drilled for body moldings. Got cab divider trim and taillight bezels in place and holes drilled as well.
02-14-2017, 04:53 PM | #130 |
Heck yeah! It won't be long now!!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
02-14-2017, 04:56 PM | #131 |
Almost ready to tear down one last time!
02-15-2017, 01:33 AM | #132 |
damn fine job so far!
02-15-2017, 01:37 AM | #133 |
Thanks for the compliments
02-19-2017, 11:37 PM | #134 |
Got the tailgate band mocked up and the holes drilled. Also worked on panel alignment this weekend. The body shop has been great about having me be part of the work.
02-27-2017, 02:24 AM | #135 |
Body came off Friday and primer was put on cab and front end. Pretty pleased with the epoxy primer.
02-27-2017, 02:27 AM | #136 |
Got Cpp tubular control arms installed today and also headers fit.
02-27-2017, 11:55 AM | #137 |
Looks good bro
02-27-2017, 12:44 PM | #138 |
You will be driving it before you know it!
02-27-2017, 02:10 PM | #139 |
Great work! Looks like you moved on with mounting the body moldings. Any advice on hole size and approach you have concluded now that you've had a chance to work through the install?
02-27-2017, 02:14 PM | #140 |
I used stick on clips where there was no access to put a nut on back side. Holes I did drill I drilled 1 size larger than the threaded stud so moldings could be moved around a bit until aligned. The spots where there is a screw going through to hold them I drilled 1 size smaller than the screw for a tight fit of screws. Hope this helps.
02-27-2017, 02:34 PM | #141 |
Low A/C mount question?
It looks like you used the Alan Grove / Vintage Air low mount A/C bracket and Sanden 508 compressor designed to work with the stock accessory drive. This set up uses the rear stock belt for A/C only. Is that correct? If so, any clearance issues with the brackets and/or compressor?
I am planning on running this setup on my LS6 and 1968 C10. I was hoping to find someone that has made it fit before ordering the parts. Mine will use the corvette offset instead of the truck but other than that would be very similar. Thanks in advance. |
02-27-2017, 02:39 PM | #142 |
My bracket came from old air products and uses the stock configuration for belt. I did clearance the frame a bit to make everything fit.
02-27-2017, 08:09 PM | #143 |
Your panel alignment looks great. Control arms look good to, kind of wish I would have went with something tubular on mine.
02-27-2017, 08:25 PM | #144 |
Thanks we spent alot of time with panel alignment
02-27-2017, 11:01 PM | #145 |
I like the full molding package you're doing. Great mix of OEM look, but with engine, trans, brakes, and suspension right up-to-date!
02-27-2017, 11:13 PM | #146 |
Its a Truck Thing......
How did you fabricate the fuel system lines? Can you take a pic of the lines coming off the engine to the frame?
Thanks, Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
02-27-2017, 11:46 PM | #147 |
I used 6an push lock hose with 6an hose holders
02-28-2017, 09:11 AM | #148 |
Still Learning
Looking good!
03-06-2017, 10:51 AM | #149 |
Thanks everyone. This weekend we worked on fitting the new tailgate and got trim holes drilled for upper gate molding. Final prime and block this week then color next week!
03-06-2017, 10:59 AM | #150 |
Picture of tailgate ready for primer
