02-17-2017, 03:02 PM | #1 |
My 67 C20 Build thread.
O.k.... I hope that I have the right forum, If not, please move :-)
Sell, my story will start as a recovering Mopar guy, I got an itch to do a GM Pick-um-up truck and went on the hunt, A friend found this about 70 miles away. She's only been on the road from the original owner, after the Original passed, the truck changed hands twice before i found it, sat both times, so i'm working with a fairly virgin piece. I was told she was a 327, 4 speed truck. |
02-17-2017, 03:08 PM | #2 |
Re: My 67 C20 Build thread.
spend the other day taking the front end apart, Picked up a few of 74 spindles with disks on it, will put disk on the front, after pulling her apart i checked the engine, ran the numbers and found it's not a 327, but a late model 350 4 bolt. It spind sfree, will inspect and do a minor rebuild on it. Also found a busted sway bar and sway bar mount, looks like someone pulled the ol girl pretty hard... Floors are nice, she has the normal work needed
cab corners inner and outer rockers front cab mount and one section of floor. Frame is extremely solid... The plan, new brake system, new brake lines, lines, drop her lower, make her run and drive, enjoy the hell out of her. and keep the 8 lugs, cause that just looks cool! |
02-17-2017, 06:05 PM | #3 |
Good solid foundation, keep pics coming.
Greg |
02-18-2017, 01:40 PM | #4 |
subscribed
02-18-2017, 10:58 PM | #5 |
02-20-2017, 08:20 PM | #6 |
Todays work. Cleaned and undercoated in the fenders. Bed removal. Frame cleaning and bed rails repair.old cab corner "repair" removed and inner and outer rockers dry fit.
02-20-2017, 08:24 PM | #7 |
off to summit to order some more odds and ends lol
02-20-2017, 08:26 PM | #8 |
I didn't know these beds unbolt into 4 pieces, as old as she is, i was able to disassemble the entire bed and only had 3 busted bolts lol
02-20-2017, 09:26 PM | #9 |
Nice looking truck project But it looks more like a 68 than 67?
02-21-2017, 07:49 AM | #10 |
Very nice! I'll be following along...
02-21-2017, 08:23 AM | #11 |
02-21-2017, 01:35 PM | #12 |
Keep the pics coming! And nice truck
1970 Chevy K/20 truck 350 4 speed. Soon putting in a mild built 400 small block. My daily 1970 k20 - http://67-72chevytrucks.com/vboard/s...=1#post7568564 |
02-21-2017, 09:34 PM | #13 |
should be a day or so for the new parts to come in, will get back on her this weekend :-), or maybe in a few days.
02-27-2017, 08:35 PM | #14 |
Some floor rot removed. 1 cab corner done. Door adjusted and lock fixed. after sitting in a year for 8 years the lock mechanism was jammed and stuck, removed it, parts cleaner soak and wire brush freed it up, grease and cleaned so its no longer an issue :-) Im far from a welder or a body guy, but i do the best I can, bottom rocker was mocked up in these pictures.
02-27-2017, 08:38 PM | #15 |
Rear cab mount. Front cab mount. Inner cab corner and inner and outer rockers done. Just got to burn it all in and i get to start on the drivers side.
I made the inner cab corner piece, happy with the way it turned out. |
02-27-2017, 11:04 PM | #16 |
ohhhh and BUILD SHEET :-)
02-27-2017, 11:47 PM | #17 |
Wow you just made me want to look under my seat.
Wanting to add I am subscribed. You are doing an awesome job. Last edited by Getter-Done; 02-27-2017 at 11:57 PM. Reason: add sub |
02-28-2017, 07:47 AM | #18 |
Coming along real nice!
02-28-2017, 11:22 PM | #19 |
Thanks for the compliments :-)
Today I Removed drivers side floor... Removed front cab support. Replaced cab support and floor. Cut out read cab support and read cab corner. Started mock up on that...I will have my kids tomorrow so this is it for a few days, I will try to get some more work Thursday :-) I need to get this body done So I can get her to make some noise LOL |
02-28-2017, 11:24 PM | #20 |
she looked so much more solid sitting in the field for 8 years LOL
Cant wait till I can hide my ugly welds with seam sealer LOL |
