02-13-2017, 04:48 PM | #26 |
Re: Door glass not sealing
Son of a... my plans were to replace all my glass with factory "green tint" glass. How hard is it to cut a flat piece of glass to match another? Sheesh.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
02-13-2017, 04:51 PM | #27 |
I called a local glass place and they said they could cut it out of laminated glass if i had a template. The glass i had trouble with came from LMC but i went ahead and ordered oer brand glass today. Ill let you know if it fits better.
02-21-2017, 12:17 PM | #28 | |
The Older Generation
Wow, I forgot about this thread Rob. Yes that is the tab. Here is a thread I posted some pictures in... http://67-72chevytrucks.com/vboard/s...d.php?t=633866 Here is a picture of the "J" clip with the measurements also. LockDoc
02-21-2017, 01:12 PM | #29 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
02-21-2017, 11:17 PM | #30 |
I got my new oer door glass and installed the drivers side today. The glass is much closer to the original but i am still lacking a little from the top of the glass going up against the door run seal. It is up in the run but not compressed at the top. Is this common?
02-22-2017, 09:56 PM | #31 |
Talk to me guys
02-22-2017, 10:00 PM | #32 |
Without actually being there it is really hard to say what is going on. I guess I would just replace the regulator and see what that does. LockDoc
02-22-2017, 10:03 PM | #33 |
I was just wondering if the top of the glass is suppose to press against the run channel seal
02-22-2017, 10:39 PM | #34 |
This. My guess is the door itself isn't formed correctly?
02-22-2017, 10:53 PM | #35 | ||
LockDoc
02-22-2017, 11:41 PM | #36 | |
There is plenty of depth in the glass channel for it to seal the glass after reshaping. |
02-22-2017, 11:47 PM | #37 | |
To confirm this remove the glass run channel from inside the door, just unbolt it at both places and slide it down a bit. Your window will then roll all the way up into the top of the door confirming the problem. Then when you reinstall the channel make sure at the transition to the door the run channel is fully seated. Problem solved. You didn't need new glass. The overall shape of the glass is not all that critical since the channel is so deep. |
02-23-2017, 11:24 AM | #38 | |
I have reformed everything on this door. Believe it or not I have been building these trucks since 2004 and this is the first aftermarket door I have ever worked with. It will also be the last.... The only reason I have it is because it was on the truck when I got it. I have finally figured out that part of the problem is that the holes for the door latch are punched in the wrong place. If the glass doesn't seal at the top you will get wind noise, It doesn't matter how deep the channel is. LockDoc
02-23-2017, 09:30 PM | #39 | |
02-24-2017, 12:03 PM | #40 |
Can you take a pic of what you're referring to.
The channel at the top of the door is pretty "deep" Are you saying when the window is up there's an actual open gap between the glass and seal?
02-25-2017, 12:53 PM | #41 |
02-25-2017, 02:53 PM | #42 |
Take out that back weather-strip channel at the back of the door then roll it up and post back. I'm sure the top to back run weatherstrip is not seated inside the door and the glass is binding at that point.
04-10-2017, 08:40 AM | #43 |
Did you figure it out?
04-10-2017, 08:51 PM | #44 |
04-11-2017, 03:51 PM | #45 |
I'm having the same problem, my window will not roll all the way up. After a lot of frustration, I figured out that the metal frame going around the top of my new aftermarket door, is not formed correctly. I plan on removing it and welding the old door frame back on.
